I've got a problem with the IC1604. I see that I've got the first bits but there is a problem with a SREG. Whn I'm trying to prtect 0x88 and 0x42 there is no such a posibility. It's suck on 0x90 and 0x45 and when i'm trying to write it nothing changes. I can change the batch, but can't do anything with SREG. When I'm trying to unprotect blank chip it's stuck on 0x90 and 0x45. Can i do anything with that? Thanks
I've tried the file but unfortunately it doesn't work, I don't have standby, the TV is completely dead.
any help please?
thank you so much
Did you set and write the correct "status register" (0x88, 0x42) after writing the corrected dump? Most likely, he (dump) again flew off after applying voltage to the board.
Sorry but I don't know how to do it (0x88, 0x42), I have a RT809H programmer.
Could you help me do it?
thank you
Now the standby light is on and it blinks when you press the power button but it does not show any image. The heatsink chip gets very hot.
I hope your help
thank you
I hope your help
thank you
Well, how can I help you, this behavior can be if someone else's firmware was written into it, from another TV, this dump (the one that you posted it native?
The file sent by the original extracted from the television with RT809H there is no doubt.
I hope you can help me
thank you
There may be a problem when removing or installing spi flash 25q40, the components moved around this memory (resistors ...), if you used a soldering station with hot air, the flash itself is not working properly, there may be a problem in the T-Con firmware (25Q80), the problem is in panels...
