samsung UE49MU6120KXXU image problem
  • ioanban
    replied
    Re: samsung UE49MU6120KXXU image problem
    Originally posted by Davi.p
    Burj Khalifa!
  • Davi.p
    replied
    Burj Khalifa!
  • ioanban
    replied
    The flex that joins main board to the panel
    I have just done that and it's working. I goy 5 very thin lines in stead and the quality of the picture is lower but the flickering has stopped. All together, acceptable results, if you are not to close to the tv you won't notice anything wrong.
    Thank you guys !
  • Davi.p
    replied
  • ioanban
    replied
    Originally posted by mmartell
    Easier to try and cover some of the pins on the flex cable with a small piece of tape than to cut a tiny trace. Plus it's reversible by removing the tape.
    As per earlier instruction you need to at least narrow which side you should be working in.
    What flex cable are you referring to because it doesn't have a tcom board
  • Davi.p
    replied
    yes i'm very sorry, i made big mistake, tape method should work..
  • mmartell
    replied
  • Davi.p
    replied
    Yes, in the truth i've never done this particular modify and i feel it's very difficult, must use a cutter with very sharp blade and putting it at least 45 degrees or more to the surface and slowly cut paying attention to not to cut adiacent trace.. maybe with help of magnifier..
  • ioanban
    replied
    it's not easy, on the top image i've marked the tracks to be cut, must make cuts of the near track translated not in line, so it's more easy when you join them again, the round pads covered in green have corrispondance with signals labeled in the bottom picture, cut only the ones with CK.., cut until defect goes away , if it doesn't join them all and cut the ones in the other side...
    Don't worry about your english, it's perfect !
    My problem is that i don't know how to physically cut those tracks, i've never done it or seen anyone doing it before.
    Thank you for the help Davi
  • Davi.p
    replied
    Bohsboha it's generally not good to hijack an other one's thread, post your own thread, your defect is different..
  • bohaboha
    replied
    hi again Davi.p no I am not Ioanban and my English is worse than yours. I have a samsung tv problem and am trying to find a solution to the one it is posted here : Samsung UE55KU6575U SHOWS ONLY HALF SCREEN if you can help me I will be very happy
  • Davi.p
    replied
    Who are you? Not Ioanban?
    It's not easy with my english...
    In the bottom image you see the silkscreens of the signals that passes in the traces i have marked approximately in the top image, the signals labels refers to the green round pads(testpoints), counting the corrispondant pads you'll cut the traces one by one..
  • bohaboha
    replied
    Good Evening Davi.p I have read your answer and tried to figure out how to go about implementing your advice but could not. can you please describe a little more in detail how to proceed.thank you
  • Davi.p
    replied
  • ioanban
    replied
    must cut one by one tracks with signal name with CK... and see if defect goes..
    Good morning Davi,
    Could you tell me how am I supposed to do that ? a video would be helpful or some description.
    Thank you
  • Davi.p
    replied
  • ioanban
    replied
    I have already tried to fiddle with the strips from the panels but i haven't noticed any changes on the screen .
    You have some pictures with the panel boards, i have don them in sections so that you can see them better, attached here .
  • Davi.p
    replied
    panel's boards are under a metal frame under speakers...
  • ioanban
    replied
    in this case i have no answer for now, must take pictures of the panel's boards searching for silkscreens of signals, if you find some clk-something, must cut them one by one, one side at a time..
    Davi, i have uploaded pictures with all the boards in the first post .
  • Davi.p
    replied
    09-07-2024, 05:50 AM
  • howardc64
    Samsung UN55JU650DF network/streaming problem
    by howardc64
    Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
    This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
    07-09-2025, 12:44 PM
    09-06-2024, 11:40 PM
    09-06-2024, 08:40 PM
