LG 50PH670S no video only audio
  • xblood88
    • May 2021
    • 14
    • Italy
    hi everyone i have a problem with this plasma. At any moment the video is no longer visible and only the audio is heard. Is there anyone who can help me? i turned on the tv and noticed a hum on the ysus and the heatsinks are all cold on both ysus and zsus. The voltages vs va are all correct. Disassembling the buffer board there is an integrated in short circuit because it is in continuity. Thanks for the help
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: LG 50PH670S no video only audio
    Post some photos of the board and also of the area around the component that is short circuit.
    • xblood88
      • May 2021
      • 14
      • Italy
      Ok this Is a photo
      • dick_barton
        • Aug 2015
        • 6642
        • Wales
        In photo 2 you have the cable disconnected. Are you saying that one of the two buffer IC's shown are short circuit.
        Can you post a photo of the panel label
        • xblood88
          • May 2021
          • 14
          • Italy
          I disconnected the flat cable because on the contacts of that flat it gave me continuity so I assume that one of the two buffers is shorted and I tried with the disconnected one if it turned on the screen after which I stopped and asked on the forum
          • dick_barton
            • Aug 2015
            • 6642
            • Wales
            If the buffer IC is shorted then you will need to replace the circuit board unless you are able to or have a friend who can replace the faulty IC.
            With it disconnected did you have a picture with just the bottom missing?
            • xblood88
              • May 2021
              • 14
              • Italy
              Ok
              • xblood88
                • May 2021
                • 14
                • Italy
                with the flat disconnected I did not get any image, I ordered the spare ysus but I would not want to burn it again
                • dick_barton
                  • Aug 2015
                  • 6642
                  • Wales
                  Can you measure -VY which as shown in the photo. Your meter leads connect as the arrows show red to red, black to black. Be careful not to short the meter lead on the heatsink.
                  • xblood88
                    • May 2021
                    • 14
                    • Italy
                    I measure 36/37 v
                    • dick_barton
                      • Aug 2015
                      • 6642
                      • Wales
                      It should read 190V. Was the last ribbon cable still disconnected. Can you post a photo of your board. Bright and clear.
                      Edit
                      You did put your black meter lead on -Vy and the red meter lead on the +Vy to take the measurement? Your meter leads should be connected to the two points at the same time.
                      • xblood88
                        • May 2021
                        • 14
                        • Italy
                        measurements are made correctly and all cables are properly connected, heatsinks are cold
                        • dick_barton
                          • Aug 2015
                          • 6642
                          • Wales
                          Had you reconnected the bottom cable that connects to the short circuit buffer and then taken the measurement?
                          • xblood88
                            • May 2021
                            • 14
                            • Italy
                            Edit
                            • dick_barton
                              • Aug 2015
                              • 6642
                              • Wales
                              If the bottom buffers are short circuit then I would remove the ribbon cable and make certain that it is clear of any obsticles and then do that check again.
                              • xblood88
                                • May 2021
                                • 14
                                • Italy
                                measured even with the ribbon cables of the buffers disconnected and nothing changes
                                • dick_barton
                                  • Aug 2015
                                  • 6642
                                  • Wales
                                  If that the case then it looks as though there is a problem with the Ysus board.
                                  Wait and see what other forum members can advise.
                                  • xblood88
                                    • May 2021
                                    • 14
                                    • Italy
                                    ok thank you very much I have already ordered a ysus to replace but I would not want to burn it because the buffer board is shorted
                                    • xblood88
                                      • May 2021
                                      • 14
                                      • Italy
                                      you know what transformer this is because it's broken
                                      • dick_barton
                                        • Aug 2015
                                        • 6642
                                        • Wales
                                        Why do you think the transformer is broken.?
                                        I think it's the one that produces the -Vy but I'm not 100% exactly sure.
                                        • samson7point1@yahoo.com
                                          Help troubleshooting an audio problem with an RCA SGT-250 CED Player
                                          by samson7point1@yahoo.com
                                          The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
                                          The player processes the audio signal using two different reference frequencies. The "R"...
                                          04-30-2024, 11:22 AM
                                        • Hakuu
                                          by Hakuu
                                          Hi There,
                                          More Details
                                          TV Model - LG OLED77G1PUA
                                          07-12-2023, 02:37 PM
                                        • ItepK
                                          Panasonic TX-P42G30E green light blinking, no video, no audio
                                          by ItepK
                                          Hey everyone!
                                          I've gotten this TV for free, neither have it seen a TV repair man, neither have it been opened before.
                                          This post describes my entire troubleshooting process of this TV.
                                          When I turn it on using the ON/OFF switch at the side of the TV, the light rapidly flashes green, then it stays on, but it does not react to any of the remote buttons, side buttons, and doesn't play audio.
                                          I've taken the unit apart, and I've started to check some voltages:
                                          • On the P11 connector, there is 15V DC only for a brief moment, then it goes
                                          12-22-2023, 05:06 AM
                                          HP Compaq dc7700p Intel Core2 Duo Processor E6300 2x512M/80G DVD-ROM WXP Pro Small Form Factor PC E6300 Specification for Upgrade or Repair
                                          This specification for the HP Compaq dc7700p Intel Core2 Duo Processor E6300 2x512M/80G DVD-ROM WXP Pro Small Form Factor PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq dc7700p Intel Core2 Duo Processor E6300 2x512M/80G DVD-ROM WXP Pro Small Form Factor PC boardview and Compaq dc7700p Intel Core2 Duo Processor E6300 2x512M/80G DVD-ROM WXP Pro Small Form Factor PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will...
                                          09-12-2024, 03:36 PM
                                        • SolarFlare
                                          Mi TV 4 Pro-Samsung Panel LSC550FN20 - Video problem, backlight and Audio works fine.
                                          by SolarFlare
                                          My barely 3 year old TV has stopped displaying video, although the video output comes for a few seconds after turning ON which displays the manufacturers logo then shows the home screen (all this with some blue flicker) then the video goes blank and the screen is dark blue with the backlight on. The audio output works perfectly and the TV also takes in voice commands(smart TV).
                                          The TCON board has the following Chips -
                                          Samsung VTU63A0
                                          RT6939 - 2nos.
                                          and all these chips are getting real hot within a minute, I dont know if this is normal....
                                          06-26-2022, 08:58 AM
