firmware real dissaster toshiba 55v5863dg
  • pep2k21
    • Dec 2020
    • 35
    • Spain
    hi everyone, thanks in advance, any help is welcome.
    1. tv only show logo and "blue" screen. backligth on.
    2. do a vestel firmware update and works but no remote control. working using app in mobile phone with ir. could find the thosiba one.
    3. do a toshiba firmware update for this model but get error at 24%
    4. have the brilliant idea of mixing the boot.bin from vestel in toshiba firmware to be sure about how stupid i can be. i can surprise sometimes.
    5. tv gets the update with no errors. then never again showed backlight anymore. led still blinks red and orange. if i put usb with firmware and press ok on mobile phone using vestel remote, led blinks faster. has response to that.
    wait i can do better.
    6. i find at the internet the dump files from two memorys. i desolder them, program then with this files that are for my model from toshiba and now i have only a green light with no response at remote, no blink.
    i think is missing firmware, in stead of being corrupt (blink changing color)
    should a try again to reprogram, buy new memories or look for another board directly and dont touch it too much?
    thanks guys
  • pep2k21
    • Dec 2020
    • 35
    • Spain
    Re: firmware real dissaster toshiba 55v5863dg
    fixed. tv is working again
    • dick_barton
      • Aug 2015
      • 6642
      • Wales
      How did you resolve your problem?
      • pep2k21
        • Dec 2020
        • 35
        • Spain
        reprograming nand memory with correct firmware. first time my friend did and his programmer did not worked fine. slow reading and writing but no errors. i ordered a tl866ii plus, arrived this morning and today did my first tsop soldering looks not too bad
        tv started as a new configuration. everything perfect
        • pep2k21
          • Dec 2020
          • 35
          • Spain
          p.s. my model exactly is 55U5863dg and used firmware for 55V5863dg
          mine is U, worked V firmware
          • raspic
            • Dec 2014
            • Spain
            Hi:
            Can you upload dumps files of this toshiba 55V5863DG. I have same problem.
            Thanks.
            • inv4der
              • Mar 2015
              • 26
              • Poland
              Hello, I am also looking for this software for 55V5863DG. How can you send it.
              • toubia
                • Oct 2021
                • 11
                • france
                Hi, if I find it, come back and tell you here
                Main board 17MB130S
                Panel VES550QNYL-2D-N01
                RT809H programmer
                it is this card and how have post, I can put a kind link upload?
                once if I have the file I put here
                • toubia
                  • Oct 2021
                  • 11
                  • france
                  I saw a, 2 place but can not download if you want the link, or I send you by message.
                  • lagri
                    • Spain
                    thanks guys
                    I have a similar problem, the tv turns on, the Toshiba logo appears,after that screen goes black, but the backlight is on, the frontal led blink green and red continuously, but no image appears, on the back the led of the optical audio out is on.
                    My model is 55V5863DG, can yous end me the nand file?
                    Thanks in advance.
                    • Fesmitronica
                      • Oct 2021
                      • Portugal
                      Hi
                      Same problem with 55V5863DG . anyone can help???
                      • anlu
                        Vestel Firmware - Toshiba 32W133DN
                        by anlu
                        Hello, i have an old Toshiba 32W1333DN (sorry, misspelled the headline) TV that had the standby led green/red flashing and no lightup problem, i repaired it by measure the led output as suspect led problem, i measured the LED:s one by one and found one bad led, i replaced the the led-straps and the TV works.
                        Now i need to update the software because the new rc "RM-L890" does not work and i think maybe it could be an firmware issue?, i have struggled to find it without any success because all of the links where invalid, i contacted Toshiba but they do not support this model...
                        02-04-2023, 12:59 AM
                      • cheeky2
                        Toshiba 49U7763DB (Mainboard: Vestel 17MB120) firmware issues after sporadic power cu
                        by cheeky2
                        I have this Toshiba 49U7763DB Tv which was suffering issues after various electrical power cuts, which happened in quick succession
                        Originally the TV was powering on and then very shortly powering off. I managed to get into the menu structure before powering off and carry out a first time installation of the TV. Which didn't make much difference. I have managed to factory reset (that didn't make any difference either).
                        The firmware inside the 17MB120 is corrupted and is causing some strange issues so my question is does anyone have any suitable firmware for this model?
                        Details:...
                        08-17-2023, 04:34 AM
                      • Mc_Millian
                        Toshiba 50lf711u20 fire tv remote not pairing
                        by Mc_Millian
                        I was wondering if anyone could help my in pairing a remote with a Toshiba fire tv?
                        The Tv model number is: 50lf711u20 Rev B.
                        I've already replaced all the the circuit boards within the tv along with the I.R. sensor receiver.
                        I've tried 3 different remotes which should be fully compatible with this TV.
                        Oddly enough. A few if the buttons on all of the remotes actually work. Even without pairing...which makes no sense.
                        The power button, along with the volume,back,select, and directional...
                        04-07-2022, 12:15 PM
                      • Bazilwrc164
                        Request: Firmware for Hitachi 42HXT12U (Vestel 17MB95M, VES420UNDL Panel)
                        by Bazilwrc164
                        I’m looking for a USB firmware file or EEPROM dump for a Hitachi 42HXT12U TV.
                        The mainboard is a Vestel 17MB95M, and the screen panel is VES420UNDL.
                        I recently replaced the mainboard with another 17MB95M, but it’s programmed for an LC420DUJ panel, and I’m getting no picture. I’d like to flash the correct firmware via USB or update the EEPROM if needed.
                        If anyone can provide:
                        • A working USB firmware file (like upgrade_loader.pkg or mb95_m.bin)
                        • Or a compatible EEPROM dump
                        07-23-2025, 12:15 PM
                      • RAZ777
                        Toshiba 40L3653DB Vestel firmware
                        by RAZ777
                        Hi Guys,
                        I have a Toshiba 40L3653DB with flashing green/red led - firmware fault.
                        It has the vestel 17MB110 board.
                        Anyone know where I could get firmware?
                        02-16-2022, 07:56 AM
