Vestel 17MB95M Mainboard LVDS Chip?
  • samtron123
    • Dec 2012
    • 77
    • germany
    Hi
    Vestel 17MB95M mainboard LVDS chip Q33 has no power ??
    Can anyone help me?
    many thanks
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: Vestel 17MB95M Mainboard LVDS Chip?
    Where is Q33? Any photo's?
    Are all the 0 ohm resistors OK?
    Is the fuse OK?
    What are the IC numbers in the red box?
    • samtron123
      • Dec 2012
      • 77
      • germany
      here is the yellow circle Q33 and I will contact you again
      many thanks
      • samtron123
        • Dec 2012
        • 77
        • germany
        Is the fuse OK?
        thank you again that was the fuse :-)
        • dick_barton
          • Aug 2015
          • 6642
          • Wales
          Was the fuse blown?
          • samtron123
            • Dec 2012
            • 77
            • germany
            Yes, that works again, thank you very much
            • samtron123
              • Dec 2012
              • 77
              • germany
              Hello everybody
              the TV flashes 23 times and is restarted why ??
              the start screen is TELEFUNKEN no longer goes on
              Thank you
              • acedogblast
                by acedogblast
                11-02-2024, 05:13 PM
              • DynaxSC
                ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                by DynaxSC
                Hi
                I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                Today, 12:20 PM
              • FlailingEngineer
                Help with Bush Tv (Vestel 17mb95m Mainboard)
                by FlailingEngineer
                Hi, I was recently given a Bush Smart TV by a friend and the main board seems to be hanging on by a thread.
                Before we get to that, my first obstacle was figuring out the model number since the back sticker has gone for a walk. Upon taking off the back case, I noticed the following Vestel parts, 17MB95m mainboard, 17IPS71 (what I'd assume is power supply) and a VES420UNVL-3D-S02 display panel. After doing some research I think the TV I have is a Bush ELED42240FHDCNTD3D, based on the matching image here (https://www.manualslib.com/manual/11...td3d.html#manu...
                05-31-2023, 06:52 AM
                by SMDFlea
                Bad...
                09-02-2021, 04:40 PM
              • BMCappelletti
                Asus Chromebox CN62 - wrong chip put on BIOS reader
                by BMCappelletti
                Long story short:
                - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
                - gave the computer to his son a couple years later
                - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
                - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
                (seems like the story was not that short)
                He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
                01-08-2025, 07:27 PM
