Samsung UE65F9000SLXXH
  • WhiteWolfHellas
    • Jun 2019
    • 95
    • Greece
    Hello, I have this TV for repair and the symptom is that every black background has a red colour like noise. It is not visible in the menu though. I have removed and cleaned all the flex / cable connected on the boards, nothing changed. Is that main board issue?
  • Diah
    • Feb 2013
    • 6599
    Re: Samsung UE65F9000SLXXH
    log in service menu from STB state and from there do initial (hard reset ). after you check the white balance all channel value.. write it down over here or upload screen shoot.
    • WhiteWolfHellas
      • Jun 2019
      • 95
      • Greece
      Originally posted by diah
      log in service menu from stb state and from there do initial (hard reset ). After you check the white balance all channel value.. Write it down over here or upload screen shoot.
      • Diah
        • Feb 2013
        • 6599
        if you did hard reset from service menu and there no change.... for me its One connect problem
        • WhiteWolfHellas
          • Jun 2019
          • 95
          • Greece
          I did factory reset the TV and took a photo.
          How can this be a One Connect problem though? The red background is pressent even with One Connect disconnected.
          • Diah
            • Feb 2013
            • 6599
            where are the photo its show this back ground with warning screen about connect the one connect ??????
            • WhiteWolfHellas
              • Jun 2019
              • 95
              • Greece
              You mean this?
              • Diah
                • Feb 2013
                • 6599
                now its clear..yours mainboards integrated with T-CON ..?!!?
                • WhiteWolfHellas
                  • Jun 2019
                  • 95
                  • Greece
                  No, the T-Con is separate from the main board.
                  • Diah
                    • Feb 2013
                    • 6599
                    in this case you need first to test panel reaction after you connect the one connect and feed video or other ports signal then disconnect one ribbon at time between T-CON and panel. to check if there are any different with it.
                    • WhiteWolfHellas
                      • Jun 2019
                      • 95
                      • Greece
                      Using the antenna signal (aerial) the screen turns black when I disconnect either of the T-Con flexes to panel.
                      • Diah
                        • Feb 2013
                        • 6599
                        remove the metal shield of the 2 boards the back one and the one at the middle. upload focused high resolution photos on both. we need to track the video signal R/G/B-Offset
                        • WhiteWolfHellas
                          • Jun 2019
                          • 95
                          • Greece
                          remove the metal shield of the 2 boards the back one and the one at the middle. Upload focused high resolution photos on both. We need to track the video signal r/g/b-offset
                          T-Con board
                          3-D board(?)
                          • Diah
                            • Feb 2013
                            • 6599
                            its difficult to trace the signal walking thru. need to take a look on the other boards with black cover.
                            BTW: did the "one connect" socket connected to video processing boards ( the middle one ) via the Yellow socket clip?
                            • WhiteWolfHellas
                              • Jun 2019
                              • 95
                              • Greece
                              The One Connect socket is connected in the main board. The yellow socket connects the main board with the 3-D board if that's what you are asking.
                              • Diah
                                • Feb 2013
                                • 6599
                                try first to clean and reseat the black LVDS cable from both sides.. then you have 3 gate IC on the manibiards close to this black LVDS. IC110-111-112 try to freeze or to heat to check any different at screen
                                • WhiteWolfHellas
                                  • Jun 2019
                                  • 95
                                  • Greece
                                  Did everything you said, nothing changed. Could it be a defective panel?
                                  • Diah
                                    • Feb 2013
                                    • 6599
                                    No,
                                    if you did freeze or heating ICs 110-111-112 with no change.. then you have 90% BGA at the big chip.. look on the left side of the Ics where the print line goes.. at this side of the chip need flux and refellow
                                    • WhiteWolfHellas
                                      • Jun 2019
                                      • 95
                                      • Greece
                                      No,
                                      OK, I will do a reflow and report back, thank you for the info brother.
                                        09-07-2024, 05:50 AM
                                      • Robby-Gr
                                        TV Samsung UE55HU8500L (2014) – service menu + firmware reflashing advice needed
                                        by Robby-Gr
                                        I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
                                        However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
                                        The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
                                        Additional issues:...
                                        09-27-2025, 12:02 AM
                                        LCD LED TV Service Menu Codes
                                        ALL LCD LED TV SERVICE MENU CODES
                                        Service Menu Code with Board Name
                                        China Universal Board / Jumper Board Service Menu Code
                                        Changhong Ruba Service Menu Code
                                        Ecostar LED TV Service Menu Code
                                        Orient LED TV Service Menu Code
                                        Haier LED TV Service Menu Code
                                        TCL LED TV Service Menu Code
                                        Samsung LED TV Service Menu Code
                                        LG LED TV Service Menu Code
                                        Videocon LED TV Service Menu Code
                                        Supra LED TV Service Menu Code
                                        Toshiba LED TV Service Menu Code
                                        Symphony LED TV Service Menu Code
                                        Veste/ LED TV Service Menu Code...
                                        10-31-2024, 03:58 AM
                                        09-06-2024, 11:40 PM
