Re: TOSHIBA 40L3453DB red-green blinking light
It may be my Winrar program but I still see the error message as shown.
Edit
Just updated my WinRaR and all is well. My error. Many thanks.
Attached FilesLeave a comment:
Hi Fergal22
Can you check your files. I tried to read them but winrar says error or corrupt.
ThanksLeave a comment:
Thank you for yours consideration and for following .. but i will be more happy you keep it and fix it self.
so when you flashed U10 and you got same red green flashing.. did the backlight come on ? i think no grey screen. because NAND didn't sync with SPI and main CPU, reasons corrupted or missing voltage feeding or its erased also could be BGA issue.
when you have time you can try what i asked before.. its good stuff if you learn how to communicated with via UART to capture the start log so we know whats going on beside. using the MT Tool to flash.
Perhaps you could post the bin files in the EEPROM thread giving TV model number, panel number and mainboard number. That would be of great help to anyone else like yourself with a similar problem.Leave a comment:
I
Just an update
New mainboard arrived, fitted and now tv is working
so i read the U10 and U11 chips then saved the files and flashed them to my mainboard
but i still Just get the red/green flashing light so there must be another fault on it as you say might be the NAND
I am just going to leave it working for a few days to make sure the new board is stable
Thanks for all your help, even though we never fixed the issue its been a good learning curve for me and i have learned something new
when i have some more free time i will put the old board back in and check what you suggested or
if you want it to see if you can solve the issue you can have it and i will gladly send it to you if you like?
when you have time you can try what i asked before.. its good stuff if you learn how to communicated with via UART to capture the start log so we know whats going on beside. using the MT Tool to flash.Leave a comment:
Just an update
if you want it to see if you can solve the issue you can have it and i will gladly send it to you if you like?Leave a comment:
one things more to let this threat complete with all solution , in case we flash mboot to the spi flash and there are no response from RC, there are working around by using the same CH314A adapter as serial Adapter with level 3,3V to read and write via RX & TX
On the Adapter there are jumpers need to switch it so it will be serial ( the driver are included at my previous attachment file )
we connect the TV from scart sockets
Pin 10 = RX -------> connect to Adapter TX
Pin 12 = TX -------> connect to Adapter RX
Pin 13 = GND to Adapter GND
configure the port of Mstar ISP Tool and starting the work according to the pdf how to update MB90 /MB95
the above for windows users... who are using Linux much easy to have above with terminal command line
I will try this tomorrow if i feel any better
did not want you waiting on a replyLeave a comment:
the above for windows users... who are using Linux much easy to have above with terminal command lineLeave a comment:
from all SPI dumps you flashed, we got red green flashing / green flashing /.. its sound there are no any sign from U13 NAND. so you have time until the replacements boards to arrive.. can you check if the NAND had on pins 12 & 37 3.3V ?Leave a comment:
I don't know if this site is any use to you offering a bin file for your set.
https://repairalltv.com/toshiba-40l3...mb95-download/
Or
http://www.dl.toshiba.com/dtv/NA/GB/EN/40L3453DB.html
U11, no sense at all they make dump for it.. as its part of firmware when it updated it will write part of the profile on it.. so even its blank now when it worked will not able to scan channel. and this small issue.
try post#70 also you can just put any mboot on the usb , it will not flashed. only as sync to start from usb.
Thanks or all your help and advice, its appreciatedLeave a comment:
try post#70 also you can just put any mboot on the usb , it will not flashed. only as sync to start from usb.Leave a comment:
Or
http://www.dl.toshiba.com/dtv/NA/GB/EN/40L3453DB.htmlLast edited by dick_barton; 02-22-2021, 06:52 AM.Leave a comment:
this error maybe because flashing while the chip on board. some need to be out of circuit to flashing or could be the dump was taken with other programmer more pro than CH314. also just consider the software of this CH314 are simple one.. some time need to restart it & clean Temp. ... however after searching yours boards service manual , this U11 are for T2 DEMOD. assigned to U17. so ignore it right now... and try my post #70 if this wont help... sorry i am out of any other idea to replace the boards.
I will try post 70 if that don't work i will buy another mainboard for itLeave a comment:
this error maybe because flashing while the chip on board. some need to be out of circuit to flashing or could be the dump was taken with other programmer more pro than CH314. also just consider the software of this CH314 are simple one.. some time need to restart it & clean Temp. ... however after searching yours boards service manual , this U11 are for T2 DEMOD. assigned to U17. so ignore it right now... and try my post #70 if this wont help... sorry i am out of any other idea to replace the boards.Leave a comment:
flash it with diif fileLeave a comment:
I read it twice but had it set to this W25Q80VB, as that what it says on the chip see attached picture and files
I will try again on the other settingLast edited by Fergal22; 02-21-2021, 06:12 PM.Leave a comment:
This specification for the Toshiba Satellite Pro C660-1NQ can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the C660-1NQ boardview and C660-1NQ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...09-06-2024, 05:27 AM
This specification for the Toshiba Satellite L635-10K Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L635-10K boardview and L635-10K schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...09-06-2024, 05:59 AM
This specification for the Toshiba Satellite L655-1DJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L655-1DJ boardview and L655-1DJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...09-06-2024, 05:59 AM
This specification for the Toshiba Satellite L655-19C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L655-19C boardview and L655-19C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...09-06-2024, 05:59 AM
This specification for the Toshiba Portege Z30-C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z30-C boardview and Z30-C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Portege...09-06-2024, 05:33 AM
- Loading...
