Burn in on OLED screens, is it (partially) solvable
  • Beeldbuisje
    • Jul 2020
    • 57
    • Belgium
    Re: Burn in on OLED screens, is it (partially) solvable
    Originally posted by Diah
    so if you don't know how to use yours power supply as stand alone with this part. i would suggest you stop doing any further steps.
    I can figure it out by using the service manual of this set. I've done it in previous Loewe sets, so why not on these ;-)
    But as previously mentionend, for doing those tests, I have to move the set to my workroom and need some more spare time. So for now I pause this project for a little while.
    Weather forecast become worse at the end of next week. Hobbytime then
    • Beeldbuisje
      • Jul 2020
      • 57
      • Belgium
      Last week, I had again some spare time for hobbying.
      Took the service manual of this Loewe and I found the way to have the Power supply constantly powered on.
      Tried again your suggested trick: mainboard disconnected, 24V connected, but 12V loose. T-Con doesn't anything. 12V connected, 24V loose: T-Con doesn't do anything.
      In this two cases, I measured the tension: 24V or 12V are constantly present. So, I don't think this feature is built in my T-Con.
      • Diah
        • Feb 2013
        • 6403
        how about if the both 12 & 24 V connected ( MB out LVDS from T-CON out ) what you can see on the screen ??
        • Beeldbuisje
          • Jul 2020
          • 57
          • Belgium
          Nothing... I waited for 5 min.
          12 & 24V are present, both flexcables to MB are disconnected, 4 cables to panel are connected.
          • Diah
            • Feb 2013
            • 6403
            could you please upload over here the service manual you are talking about??!
            • Beeldbuisje
              • Jul 2020
              • 57
              • Belgium
              #26
              This is that service manual of my set.
              • Diah
                • Feb 2013
                • 6403
                thanks for the SM upload. this clear your test statement above. T-CON still have other 12V feed via LVDS (XP33) which operate the T-CON FW. which we want to run as stand alone.
                i am not sure how its look your T-CON boards.. thought the photos you uploaded before give not much info if the XP33 12V pins direction TO or FROM MB , if they are from MB then...
                the test you did it before of 12 & 24V was okay.. but need other 12V to replace the feed of xp33 to T-CON. so the same 12V of PSU to T-CON can be bridged and used of course.
                • Beeldbuisje
                  • Jul 2020
                  • 57
                  • Belgium
                  #28
                  Aha, I didn't know that. I will try it asap. Maybe not this week, because I have some busy days.
                  So, beside adding 12V on the CN6 on the T-Con, do I have to connect both 12 and 24V to the T-Con coming from the power supply or only 24V connected and the 12V plug from Power supply disconnected (as you earlier mentioned)?
                  • Diah
                    • Feb 2013
                    • 6403
                    you can try this 3 scenario one after other. let it run for at least 3 minute. then leave the set discharge at least 10 minute before running the next test. BTW always give attention on the screen to see what happen. prefer little dark room.
                    1- with out cells. : 24V disconnected 12V feed only from power boards to T-CON + bridge 12V to CN6
                    2- with cells,: 24V connected, 12V from power boards ONLY bridged to CN6
                    3-Stand alone,: 24V connected, 12V connected + bridged to CN6
                    at the end leave it discharge put every things in place and feed signal (most important) and turn on.. hope you will find different at yours screen.
                    • Beeldbuisje
                      • Jul 2020
                      • 57
                      • Belgium
                      #30
                      Clear!
                      When I have some spare time again, I'll try this en let you know asap!
                      • Beeldbuisje
                        • Jul 2020
                        • 57
                        • Belgium
                        #31
                        Need some advice first before I'll execute your last tip...
                        Something strange about the 12V coming from the mainboard. When I connect everything for normal tv operation, and switch this tv on, no 12V is measured on that XP33, where it should be in according to the SM.
                        I also hit both the compensation cycles in service menu, let them completely run, never ever 12V on that plug.
                        Is it safe to connect that 12V like you said in posting #29? When it's an error in my manual or something...
                        • Diah
                          • Feb 2013
                          • 6403
                          My Post #27
                          good you had discovered this.. so please stop doing any test unless you take out the T-CON driver boards out side the set and remove the shield to post very clear focused photo of it. so we can follow the 12V described by XP33.
                          • Beeldbuisje
                            • Jul 2020
                            • 57
                            • Belgium
                            #33
                            So, the T-con in high resolution.
                            The red circled area is that point of the connector what has to receive 12V according to service manual.
                            • Diah
                              • Feb 2013
                              • 6403
                              i think all 12v pins are out of the circuit.. you can test them with ohm against GND of boards
                              could you read the eeprom ic No ?
                              • Beeldbuisje
                                • Jul 2020
                                • 57
                                • Belgium
                                #35
                                Indeed, those 12V pins are “open loop” to GND.
                                What do you mean with “read” eeprom? The part number, or read it out with software?
                                • Diah
                                  • Feb 2013
                                  • 6403
                                  no, just want to know the chip IC the no. printed on it.
                                  • Beeldbuisje
                                    • Jul 2020
                                    • 57
                                    • Belgium
                                    #37
                                    Normally it should be large enough to read it...
                                    • Diah
                                      • Feb 2013
                                      • 6403
                                      Bad answer...
                                      any way..
                                      the test (with out cells ) with every things connected as normal, only 24V from PSU to T-CON disconnected should work and the tv remain on (optic audio red led will lid on and remain on).
                                      on other hand if you force it to JB at time playing .jpg white test picture 384x2160 pixel with Red 255, Green 255, blue 255 via USB media .could help too if the there are no burn at the thin film.. thought need doing this several time. or keep playing the picture for long period.
                                      sorry that all what i know.
                                      • Beeldbuisje
                                        • Jul 2020
                                        • 57
                                        • Belgium
                                        #39
                                        This option is provided in the service-menu of this tv. Had it already in a loop for one week 24/7. Didn't improve anything.
                                        After this I started a JB, but also no improvements...
                                        Damn, probably a burn at the thin film...
                                          ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook Pro 15 OLED Specification for Upgrade or Repair
                                          This specification for the ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Vivobook Pro 15 OLED D3500QC-L1351W boardview and Vivobook Pro 15 OLED D3500QC-L1351W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                          09-07-2024, 04:30 AM
                                          Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook Specification for Upgrade or Repair
                                          This specification for the Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED BMF-72ESBB4SH boardview and 14 OLED BMF-72ESBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 07:12 AM
                                          Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook Specification for Upgrade or Repair
                                          This specification for the Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 OLED BSF-A3LA964SP boardview and 16 OLED BSF-A3LA964SP schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          Gigabyte AERO 14 OLED 9MF-E2USBB4SH Notebook Specification for Upgrade or Repair
                                          This specification for the Gigabyte AERO 14 OLED 9MF-E2USBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED 9MF-E2USBB4SH boardview and 14 OLED 9MF-E2USBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 06:40 AM
                                          Gigabyte AERO 14 OLED BMF-72AUBB4SH Notebook Specification for Upgrade or Repair
                                          This specification for the Gigabyte AERO 14 OLED BMF-72AUBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED BMF-72AUBB4SH boardview and 14 OLED BMF-72AUBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 06:38 AM
