LG22LH2000 TV, Lien Chang AIP-0190 schematics anyone?
  • OniJon
    Computer Expert
    • 82
    • Finland
    I found this TV from my workplaces electronics waste. I know it's old 2009 model and only hd ready, I just took it out of curiosity and for something little to work on. It has that Lien Chang psu mentioned. On a first look it has one resistor that's exploded, sus'cons that will need replacing juat because they're crap and according to youtube, maybe a power driver ic is in need of a replacement. Pictures are also now up.
    IC I'm talking about is strw6252 and blown resistor (or a fuse?) is R111 (dead center in the picture between main filter caps and yellow trafo), which of I have no idea what it should be because can't find schematics.
  • R_J
    • 9518
    Re: LG22LH2000 TV, Lien Chang AIP-0190 schematics anyone?
    R111 is a 2amp/125, 20N series pico fuse, also check R108 (in heatshrink), pin5 to ground, it should measure 0.4Ω It is likely good. I would replace the ic and fuse and see if it works, if it does, I would replace C105, then I would replace the other caps if you like, but they don't look bad yet.
    • OniJon
      Computer Expert
      • 82
      • Finland
      Thanks! I ordered glass tube pico fuses at 2A 250V, they should be okay or is the inrush current capability in those 20N series very important? Pin 5 to ground, R108 measured around 0.4 like you said. I also ordered new IC and better caps. Gonna report what happens when I replace all of those.
      I don't think it hurts anything to add more filtering like let's say, adding another 25v 1000uf cap to missing point at C202? What about C204, what value would be good and why it's not there? Because I have loads of caps, better to use them than let them dry.
      • R_J
        • 9518
        These power supplies are used in many different models, there is no need to add more capacitors.
        • OniJon
          Computer Expert
          • 82
          • Finland
          I know they are used in many models but I was just curious would it help with longetivity to add more filtering or would extra capacitance hurt something? I'm more than capable at component level changes, fixes and measuring stuff but designing these things is not my strong point. So "what does this do in this circuit" is out of my league a bit.
          • R_J
            • 9518
            Adding an extra 1000µf won't hurt it, the extra added capacity will add a bit more current (not very much) as it charges up the extra capcitor.
            If there was too much extra capacity it could damage the supply diode, or more likely put too much strain on the primary circuit as it would look like a short as the capacitors charged.
            • Popalwali
              Asus Nexus 7 2012 (ME370T REV 2.4) Schematics needed
              by Popalwali
              Hello Everyone,
              I will be really grateful if someone shares schematics and if possible the boardview of the old Asus Nexus 7 (2012) Tablet. The motherboard is ME370T Rev. 2.4. Now I can find schematics for the Rev. 1.0 but I could not find the schematics for the Rev 2.4. I tried to look for similarities in the Rev. 1 but there are somethings missing, plus the board i have has nearly no component names printed on it which as a newbie makes pretty hard for me to locate things. Any assistance will be appreciated. Thank you.
              08-25-2024, 11:28 AM
            • Techmanx
              Schematics Download Site
              by Techmanx
              If anyone needs schematic diagrams for any pro audio gear like what professional musicians use, such as guitar amps, power amplifiers, vintage tube amps, musical gear like keyboards, effects pedals, guitar wiring diagrams and service manuals, check out https://schematics.ca . I'm a road musician and an electronics tech and I got schematics for just about every piece of gear in my band from this site and they are free to download. It's always good to be prepared in case you fry something while on on the road, which always happens it seems. https://schematics-free.com has a lot of free audio schematics...
              06-28-2023, 12:08 PM
            • snpulse3344
              USB Audio Interface - Steinberg UR 12 or similar schematics
              by snpulse3344
              I need to find out schematics diagram of Steinberg UR 12., pcb printed these numbers YAMAHA YF989 ZM60700, I searched everywhere but I didn't find the schematics of this USB audio interface, If anyone has it please let me know and if anyone has similar schematics diagram please let me know as well.
              03-01-2024, 01:07 PM
            • nerdynerd
              HP OMEN Special Edition 16b-b0005dx 16.1" Schematics Needed
              by nerdynerd
              I spilled coffee on my laptop a year ago, and it recently died on me. I have been looking for the schematics for this particular laptop for a couple weeks now and haven't found anything. Would appreciate if someone's able to provide the schematics and would be happy to leave a small tip. Thank you.
              Product Link: https://www.microcenter.com/product/...6b-b0005dx_161
              05-23-2025, 03:54 AM
            • TimmyTurner
              Looking for Tongfang GM5TG0O schematics
              by TimmyTurner
              Hello, would anyone have the schematics and/or board view for the Tongfang GM5TG0O (aka XMG Core 15 M21, Avell A70 MOB, Mechrevo Z3 Pro, among others) or a similar model?
              I'm trying to debug an issue with the webcam module. Actual camera module and eDP cable both replaced already, but issue persists (glitched image, faint LED indicator, perhaps a power issue?). Having the schematics and/or board view would help a lot...
              05-18-2025, 09:51 PM
