60" Samsung plasma, #PN60E550D1FXZA issues:
  • roadrunninmark
    • Apr 2019
    • 11
    I reposted as I couldnt get the model # in the title before:
    I have a 60" Samsung TV, model #PN60E550D1FXZA, that the picture will freeze, will see strange green small lines, they get somewhat wavy, then the TV restarts itself. It doesn't do it right away but after being on for a little while. I believe it took a hit from a surge through the cable box and HDMI cord. The cable box had to be replaced and that HDMI plug in no longer worked. I got a new cable box and plugged into another HDMI plug and all was well for a few weeks. HDMI cable is fine as I am using on another TV. Then the TV started to act up as described. It also acts the same when using the smart TV feature (netflix, etc.) so I know it isn't isolated to the HDMI inputs.
    What do you think is bad and can that piece be replaced (bad main board or?)? I know it is an older TV and I am willing to give it a try to fix. I'll probably get a new TV anyway but would like to keep this one for another room.
    All help is appreciated!
    Mark
  • Nick's Tvs
    • Jan 2014
    • 621
    Re: 60" Samsung plasma, #PN60E550D1FXZA issues:
    Assuming this is the main board in your TV,
    https://www.shopjimmy.com/samsung-bn...e550d1fxza.htm
    Then the BGA processor chip under the silver heatsink is at fault and needs to be replaced. Not reflowed, not reballed, but replaced entirely.
    • roadrunninmark
      • Apr 2019
      • 11
      Thanks forthe info Nick!
      • roadrunninmark
        • Apr 2019
        • 11
        Looks like the tv is now working with a different main board. Thanks again Nick!
          09-07-2024, 05:50 AM
        • HarleyFool
          Troubleshooting Samsung PN60E550D1FXZA Plasma TV
          by HarleyFool
          I have a Samsung 60-inch plasma TV, model PN60E550D1FXZA with factory remote. When cold, the TV will turn on and operate normally. After operating for longer than 30-60 minutes, if the set is turned OFF and then back ON, it will turn back ON, but there is no picture (screen remains black). I can confirm set is ON because I can hear audio from the speakers when I operate the VOLUME UP/DOWN control on the remote. If I allow the TV to rest (cool), it will eventually turn back ON with picture restored. That may take an hour or overnight.
          I have removed the back of the TV and looked...
          12-21-2021, 02:40 PM
          09-06-2024, 11:40 PM
          09-06-2024, 08:40 PM
