ASUS R7 360 no image but drivers install fine.
  • PopcornMobo
    • Dec 2017
    • 53
    • Lithuania
    I bought this ASUS R7 360 OC 2GD5 quite a while ago but didn't have the opportunity to properly test it, i had it in one PC and it gave no signal but was an old PC and i'd read previously that this card can give no image on older HW.
    Until recently i didn't have a mobo with an IGPU but now i have one and decided to give the R7 360 another go.
    With the display plugged into my IGP i checked if the card was being detected.
    It was detected and it even installed the drivers without any issues, but when i plugged my display cable into the GPU i would get no signal.
    Externally the card looks like new, no scratches or knocked off components as far as i can see.
    Not exactly sure what could be happening, The card does not give a black screen, rather it gives no signal at all ( screen says no signal whenever the card is plugged in ).
    If you guys have any suggestions, i'm all ears.
    PS: not sure if this is the right area to post a GPU related thread, didn't find anywhere else to put it.
  • japlytic
    DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
    by japlytic
    In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
    Tried (only with keyboard/mouse connected):
    • BIOS + database update
    • Using latest Windows 11 image built with official image creation tool
    • Previous setup version for Windows 11 installer
    • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
    • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
    • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
    06-19-2025, 04:59 PM
  • alipiorpz
    Error install GPU Drivers in Asus Vivobook K6502HC
    by alipiorpz
    Guys, I have an intriguing case on my workbench.
    I have an Asus Vivobook K6502HC.
    It detects the RTX GPU in the BIOS, but it won't install the drivers in Windows.
    Could anyone tell me what's causing this?
    11-10-2025, 03:25 PM
  • DynaxSC
    by DynaxSC
    06-14-2024, 03:49 PM
  • Dreigas
    Asus TUF Gaming FX506LX laptop just stuck at random time
    by Dreigas
    I've got a problem with my Asus TUF Gaming FX506LX laptop. I bought it as a non-working unit it had been completely drenched in a sweet alcoholic drink and was left for a year... When I got it, the motherboard wasn't in terrible shape, but I had to clean a lot of areas—about 1/5 of the motherboard. There was some corrosion, but I managed to clean it up and re-soldered where I saw issues under a microscope.
    One of the two primary MOSFETs was fried (PQ33 fried and PQ34 were fine), so while I was waiting for a replacement, I desoldered it and created a short....
    07-27-2024, 05:58 AM
    ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook 15 Specification for Upgrade or Repair
    This specification for the ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD boardview and ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
    09-07-2024, 02:50 AM
