Samsung UN50EH5300F Repaired Backlights
  • neilc6
    • Nov 2015
    • 1550
    Got this TV with no backlights and found 16 out of 90 bad. There was 1 or 2 out in every strip. Ordered a full set of replacement strips from ebay seller asa.vd.pc which were a bit cheaper than shopjimmy.
    Bit tricky getting the panel lined up on re-assembly and it was sliding on me once I had the tv vertical. Trick is to make sure the outer bezel that holds the panel is snapped in all the way (no screws) and the panel is perfectly flush.
    With the TV on, I noticed it was set to "DYNAMIC" mode on all inputs which sets the LEDs at maximum brightness 20 out of 20 max.
  • gavric
    • Jun 2011
    • 65
    Re: Samsung UN50EH5300F Repaired Backlights
    That is why they burn up, when they are straight from the box set to backlight on highest for perfect picture apperance + will keep consumers coming back to buy new tvs after 2-3 years.
      09-07-2024, 05:50 AM
    • max789
      Samsung UE48H6410 replaced Mainboard but backlights doesnt go on
      by max789
      Hello, I have a problem with my Samsung UE48H6410SSXZG with the main board BN41-02156A and the power board BN44-00709A. Everything seemed like this, the TV could no longer be switched on, the standby LED always flashed 5x2 times. Backlight was off and no sound from TV. Also made the flashlight test and there was no picture.
      I made the following tests:
      1. Disconnected the main board from Power Board = backlight works.
      2. Connected the main board and disconnected the T-Con = backlights does not work.
      So I ordered a main board from Ebay also BN41-02156A but from...
      01-18-2024, 06:56 AM
      09-06-2024, 11:40 PM
      09-06-2024, 08:40 PM
