Re: Lg 50pj550 no STBY light
i have two multimeters, i know is imposible but is corect read 327 v dc.
in p813 socket i have 0v on all pins.
here is manualAttached FilesLeave a comment:
Well ,we need to get the other Voltage reading correctly first because you are report something that is impossible, I.E. 390VDC when no AC is present on the bridge. I do NOT want want to be chasing ghost due to wrong information/Data.Leave a comment:
ok, what voltage should i have in stby and where, because i have no voltage than the above mentionedLeave a comment:
5.1V switched supply as I already indicated.
From your training manual:
When RL_ON arrives, the run voltage +5V source becomes active and is sent to the Main Board via P813 (5.24V at pin 5, 6 and 7)Last edited by budm; 07-14-2018, 03:51 PM.Leave a comment:
17V switched power supply as I already indicated.
Your training manual:
'The RL-ON command also turns on the 17V (Audio B+ 16.79V) which is also sent to the Main Board.'Last edited by budm; 07-14-2018, 03:51 PM.Leave a comment:
"Fuse F302 160V" But you have 327VDC, right?Leave a comment:
If there is no AC feeding the bridge D101 then there is no way you can have that 390VDC on the main cap.Leave a comment:
Power Suration AC Voltage is supplied to the SMPS Board at Connector SC101 from the AC Input assembly. Rectified by the Bridge rectifier D101 generates a primary B+. The Power factor circuit generates a Primary supply which can be read at Fuse F302 160V. This primary voltage is routed through T301 and routed to the Standby 5V supply. The STBY5V (standby) is B+ for the Controller chip on the back of the board (IC701) on the SMPS and output at P813 pins 13 and 14 then sent to the Main board for Microprocessor (IC1) operation (STBY 3.49V RUN 5.23V). When the Microprocessor (IC1) on the Main Board receives a “POWER ON“ Command from either the Power button or the Remote IR Signal, it outputs a high (2.43V) called RL_ON at Pin 15 of P813. This command causes the Relay Circuit to close both Relays RL101 and RL103 routing AC to the Bridge Rectifier D101 which then routes the primary voltage to the PFC circuit (Power Factor Controller) 390V which can be read measuring voltage at Fuses F302 (390V) and F801 (389V) from “Hot” Ground. AC Detection (AC Det) is generated on the SMPS, by rectifying a small sample of the A/C Line and routed to the Controller (IC701) where it outputs at P813 pin 16 (4.45V) and sent to P301 to the Main Board where it is sensed and monitored by the Main Microprocessor (IC1). If AC Det is missing the set will come on, but shut off in 10 seconds. When RL_ON arrives, the run voltage +5V source becomes active and is sent to the Main Board via P813 (5.24V at pin 5, 6 and 7). The (Error Det) from the SMPS Board to the Main Board can be measured at pin 8 of P813 (2.88V STBY and 4.93V RUN), but it is not used. The RL-ON command also turns on the 17V (Audio B+ 16.79V) which is also sent to the Main Board. The 17V Audio supply outputs to the Main board at P813 pins 1 and 2 and used for Audio processing and amplification. The next step is for the Microprocessor IC1 on the Main Board to output a high (3.27V) on M_ON Line to the SMPS at P813 Pin 17 which is sensed by the Controller IC701, turning on the M5V line and outputs at P811 pins 9 and 10 to the Y-SUS board. The Controller (IC701) also uses the M_ON line to turn on the VA and the VS supplies. (Note there is no VS On Command in this set). VS is output at P811 to the Y-SUS board P201. (VA pins 6 and 7 and VS pins 1 and 2). Note: The Va is fused on the Y-SUS then routed out P209 to the X-Board Left. VS is also routed out of the Y-SUS P206 pins 1 and 2 to the Z-SUS P2. AUTO GND Pin 18 of P813: This pin is grounded on the Main board. When it is grounded, the Controller (IC701) works in the normal mode, meaning it turns on the power supply via commands sent from the Main board. When AUTO GND is floated (opened), it pulls up and places the Controller (IC701) into the Auto mode. In this state, the Controller turns on the power supply in stages automatically. A load is necessary to perform a good test of the SMPS if the Main board is suspectLeave a comment:
Without having the board connected to other board and have Voltage on the main filter caps in the PFC circuit is that relay RL101 has to be closed, so you should verify that is no DC on the coil (measure right across the coil) of RL101. If the coil Voltage is not present then it mans the contact is stuck closed. RL103 is used for bypassing the NTC when PS-ON is present.
What DC V do you have between C377?
"The Power factor circuit generates a Primary supply which can be read at Fuse F302 160V. This primary voltage is routed through T301 and routed to the Standby 5V supply." That is wrong. Where did you get the info from?Leave a comment:
by sam_sam_samI have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
I also have back when Light of America had these light bulbs available for yard lights
The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
While the Lithonia lighting fixture has all most certain bulb failure
So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
I have only had this light fixture for not more than a year if it... -
This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-07-2024, 03:40 AM
This specification for the LG Gram Ultra-Light Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-Light Laptop boardview and Ultra-Light Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-06-2024, 09:10 PM
This specification for the LG Gram Ultra-Light Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-Light Laptop boardview and Ultra-Light Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-06-2024, 08:40 PM
Hello Everyone!
I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died....06-28-2025, 02:57 PM - Loading...
