Re: Lg 50pj550 no STBY light
gnd to pin 1 is more than 20Mohm or is error measure
gnd to pin 2 is more than 20Mohm or is error measure
gnd to pin 3 10Mohms
gnd to pin 4 15kohm
gnd to pin 6 2.30 Mohms
just f302 blow up, ic still look good,
So I need the resistance reading of all the pins against GND pin.Leave a comment:
I expect in >10K range.
Did the old IC blow up or what?Leave a comment:
[QUOTE=budm;838987]That is quite low resistance on the VCC pin, it should be in a lot higher than that.
You tested that without TV plugged into the AC outlet, right?
now i have 2.66 kohms i think capacitors was charged on first checkLeave a comment:
Yes, many thanks for your help and patienceLeave a comment:
the first time when I replaced the ic301 made it short at his pins with solder i think. (i dont know where exactly i saw just flame), f302 was burned, I checked all the nearby parts and I replaced the ic301 again with a new one.Leave a comment:
How about this?
"I changed 3br1565jf ... but I had a short circuit after the soldering". What is shorted out after soldering?Leave a comment:
Side notes about this power supply board per page 40, it indicates that without main board connected the SMPS will turn on automatically, I hope that is the correct information. If it is true once we get the standby power supply to work then everything should come on without main board connected, but right now we need to get the standby power supply working first.Leave a comment:
Your reported Voltage reading on the STBY SMPS IC:
3BR1565
pin 1 drain - 327v
pin2 cs - 0V
pin3 BA - 0,1v
pin 4 VCC - 0,5V
pin6 fb - 0,1v
The reading of 0V on the VCC pin indicating the internal charge pump inside the IC is not charging up the startup/running cap C307 connected to the VCC pin. That cap has to be charged up to 18V for the circuit to start.
What is the resistance reading between VCC and the GND pin?
pin 1 drain - 333v
pin2 cs - 0V
pin3 BA - 1v
pin 4 VCC - 0,6V
pin6 fb - 0,13v
resistance is 1.30kohmLeave a comment:
Please see post 38.
We need to get the drive circuit working first.
I still need an answer to this question: "I changed 3br1565jf ... but I had a short circuit after the soldering". What is shorted out after soldering?Leave a comment:
BTW, I already see error in the training manual. I.E. page 35, 36, it shows the DC V on the fuse F302 (for protection if there is short circuit in the STBY section) for the standby power supply to be at 1.5V in stand by and at 388V in running mode. So how does the STBY POWER SUPPLY run at 1.5V on the filter cap C305? I guess no one caught that during training session.
I did not look at the whole thing yet in details to see if there are other errors.
According to the training manual, in Standby mode the standby power supply will be putting out 3.46V, when TV is turned on then it jumps up to 5.14V, looking at the trace on the bottom side of the board it looks like it is done by the switched Q351.Leave a comment:
3BR1565
pin 1 drain - 327v
pin2 cs - 0V
pin3 BA - 0,1v
pin 4 VCC - 0,5V
pin6 fb - 0,1v
What is the resistance reading between VCC and the GND pin?Leave a comment:
According to the training manual, in Standby mode the standby power supply will be putting out 3.46V, when TV is turned on then it jumps up to 5.14V, looking at the trace on the bottom side of the board it looks like it is done by the switched Q351.Last edited by budm; 07-14-2018, 04:51 PM.Leave a comment:
The reading of 327V on the Standby power supply filter cap C305 is corrected and as expected. But when you start reporting 380V on the main filter caps (C616, 617, 618) the that put doubt in my mind about your data.
1) So did you replace that SMPS IC? The reason I ask because I do not understand "I changed 3br1565jf ... but I had a short circuit after the soldering". What is shorted out after soldering?
2) Do my pictures match your board? This is important because I do not have your board in front of me to look at, all I have are pictures which make it hard to trace the circuits.
the first time when I replaced the ic301 made it short at his pins, f302 was burned, I checked all the nearby parts and I replaced the ic301 again with a new one.Last edited by dzyk2000; 07-14-2018, 04:42 PM.Leave a comment:
BTW, you did verify that the diode D351, 352 on the cold side of the standby power supply are OK, correct?Leave a comment:
2) Do my pictures match your board? This is important because I do not have your board in front of me to look at, all I have are pictures which make it hard to trace the circuits.Last edited by budm; 07-14-2018, 04:21 PM.Leave a comment:
Based on the pictures of the board I provided:
D301, 302, 306, 309 are connected in series to form rectifier for the incoming 230VAC.
The Cathode of the D309 is connected to the FUSE F302, the output side of the fuse is connected to the positive leg of the main filter cap C305 for the standby power supply section. The DCV on the C305 should be around 325VDC in standby mode.
When the TV is turned on, the PFC Voltage will be present on the main filter caps of the main power supply section, this boosted Voltage is then fed to the standby power supply section via D308 (Anode is connected to the (+) leg of the main power supply filter caps C616, 617, 618 so at this point the Standby power supply is running off the PFC boosted Voltage, this will put D301, 302, 306, 309 in reverse bias mode so they are no longer conducting, they will go into conduction mode again when TV is turned off.Leave a comment:
by sam_sam_samI have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
I also have back when Light of America had these light bulbs available for yard lights
The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
While the Lithonia lighting fixture has all most certain bulb failure
So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
I have only had this light fixture for not more than a year if it... -
This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-07-2024, 03:40 AM
This specification for the LG Gram Ultra-Light Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-Light Laptop boardview and Ultra-Light Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-06-2024, 09:10 PM
This specification for the LG Gram Ultra-Light Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-Light Laptop boardview and Ultra-Light Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-06-2024, 08:40 PM
Hello Everyone!
I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died....06-28-2025, 02:57 PM - Loading...
