LG 32LD350 goes standby
  • fddizon
    • Sep 2011
    • 555
    • Philippines
    hi
    anyone have bios backup of LG 32LD350?
    the unit when powered on, shows display back light turns off and on few times and unit goes to standby
    ive tried searching for this bin file to no avail
    pls share if you have
    thanks
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: LG 32LD350 goes standby
    With such little information. Sounds to me like you have a failing or failed backlight issue. perhaps the CCFLs are weak or the Inverter circuit has a fault. I don't think you have a firmware problem.
    • tvguy12012012120
      by tvguy12012012120
      02-07-2025, 05:13 PM
    • ngml
      Repair of an LG split AC system indoor unit PCB
      by ngml
      I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
      This indicates an error in the communication between the outdoor and the indoor unit.
      The outdoor unit is fine, so the problem is the indoor PCB.
      The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
      I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
      Does anybody have the schematics of this board,...
      02-01-2025, 12:55 PM
    • fharris1977
      Vizio D50u-D1 Dead Set No Standby
      by fharris1977
      Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
      12-28-2023, 10:25 AM
    • Crystaleyes
      Samsung BN44-00259A standby question
      by Crystaleyes
      Hi all.
      I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
      SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
      Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
      The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
      08-11-2023, 05:15 AM
    • reessi
      JSK4228-050 Power Supply Standby voltage changing! (Possible from Wharfedale LTF37K1)
      by reessi
      I am trying to re-purpose this power supply that I saved years ago from a tv with a cracked screen for a monitor but that is not really that relevent at the moment. I do not recall which tv but a google search looks like it is from Wharfedale LTF37K1.
      You may notice I made some alterations moving some components to the top and some wires which are from a 5v regulator I fitted to the 12v output as the monitor requires 5v. The standby was already at fault from the beginning, it has nothing to do with the alterations...
      Years ago it had some bulging caps...
      04-26-2021, 11:42 AM
