Re: Samsung UH50EH5300FXZA, help with a transformer?
Opinions on transferring one from another board? I have several scrappers with this IC on them
I took voltages at all the pins of the PFC IC. Here's what I came up with:
SOVP 5.Pin assignment
FB COMP RT OVP
1 2 3 4
8 7 6 5
VCC OUT GND IS
1 FB Feedback Voltage Input: 1.016v
2 COMP Compensation Output of error amplifier: shot up to .5v, dropped off slowly
3 RT Set Maximum on time: 0v
4 OVP Over voltage detection: .973v steady
5 IS Current Sense Input: 0
6 GND Ground
7 OUT Output: 0
8 VCC Power Supply: 11.95v
So if I'm seeing things right...zero volts at the output that drives the MOSFET= shorted MOSFET or bad PFC control IC?Leave a comment:
LOL I was reading it upside down! I see it now.those two resistors resistors are connected in parallel.
http://kiloohm.info/smd4-resistor/5602
5602 = 56K
754 =750K
So total resistance will be <56K
BEP may be ferrite inductor so it will show like jumper. Look for other BEPxx on the board and check them.
There are no other items marked BEP near in the PFC IC area?
With all resistors and items near the PFC IC checking OK are we thinking bad PFC IC? Should I now take pinout readings on the PFC IC?Last edited by DXseekerMO; 02-25-2019, 10:14 PM.Leave a comment:
5602 = 56K
754 =750K
BEP may be ferrite inductor so it will show like jumper. Look for other BEPxx on the board and check them.Last edited by budm; 02-25-2019, 10:06 PM.Leave a comment:
OK I think I found something significant:That tells me the pfc circuit is not running, The pfc circuit in the schematic I provided should be very similar, the only difference is your board only has one pfc fet.
Check the resistors around the ic, There are two resistor strings going to pin 1 & 4, give them a check, they are high resistance values. The schematic shows a 47Ω off pin 5 to a pair of resistors to ground, I can't make out that circuit on you board but check any resistors there, Then check the gate resistors between pin 7 and the fet's gate (10Ω)
It could be that the ic itself is bad
The ic's VCC is normally 12 volts and the ic will shut down at 9v
Post the pin number and voltage on each pin, carefully not to short a pin, Best way is to follow the trace from the pin to another component and measure the voltage there
Two resistors RP819 and RP818 that should be 20.9Mohms and 750Kohms both check at 50,900ohms. I'm guessing these are actually open and the resistance I'm getting is from other surrounding components.
I also found BEP801 that shows zero resistance. I can't make out the numbering on top but it kinda reminds me of a jumper?
Should I replace these before testing pin voltage?
From pin 7 to the gate there is 100ohms resistanceAttached Filesif you find these attachements useful please consider making a small donation to the site
Post 43
I cannot see why the readings now are so much different than what you have shown above.
Now yo have Voltage to run the PFC IC.Last edited by budm; 02-25-2019, 09:44 PM.Leave a comment:
Post the pin number and voltage on each pin, carefully not to short a pin, Best way is to follow the trace from the pin to another component and measure the voltage thereLast edited by R_J; 02-25-2019, 08:36 PM.Leave a comment:
Ok, so icp801s (pfc ic) is getting VCC, did the voltage across the main Cap. CP806S change from 160v and increase?Leave a comment:
The diodes you mentioned have a good diode reading on all.Check that DP801CS diode (on back side of board) and DP803 & DP805 diodes on top side are not shorted.
Then if you can measure the voltage across CM809 and CM814 (in standby PS_ON grounded)
Then unground PS_ON and see what the voltages do, and also check for the voltage on pin 8 of the pfc ic.
Across CM809.....PS_on grounded 11.12v, PS_on not grounded 10.13 - 10.17v
Across CM814.....PS_on grounded 10.21v, PS_on not grounded 10.89 - 11.10v
At pin8 of ICP801S there is a pretty constant 10.91 to 10.95v, PS_on ungroundedLeave a comment:
Then unground PS_ON and see what the voltages do, and also check for the voltage on pin 8 of the pfc ic.Leave a comment:
So there must be a different part of the PFC circuit that needs attention. The fact is when PS_on isn't grounded it looks like the PSU is trying to start but the main cap voltage always remains about 161v.
Should I un-ground PS_on now and try to locate the source of the up-and-down voltage, or are we still troubleshooting in another fashion?Last edited by DXseekerMO; 02-25-2019, 05:33 PM.Leave a comment:
The Voltage on the Emitter is generated by the AUX winding of the transformer which is fed to the switched Transistor QM808 Emitter (because it is PNP transistor), there will be no output on the Collector until PS-ON is present. The PFC IC running Voltage is around 12V.Leave a comment:
Redacted.
Redacted again
So what supplies voltage to pin8 of ICP801S with PS_on grounded? Is there supposed to be voltage there with PS_on grounded or were we just checking for a good pathway with the resistance test?Last edited by DXseekerMO; 02-25-2019, 04:14 PM.Leave a comment:
When PS-ON pin is grounded, I do expect at least 12V on the Emitter pin of the QM808 (PNP, It is turned off when PS-ON is grounded).Leave a comment:
On RP824 there is 022 with a line on top. Does this line denote "this side up" to read the value properly?Leave a comment:
If you look at the schematic of the BN44-00520C, there is a 22Ω between the transistor switch and the pfc ic vcc, which would make sense.Leave a comment:
RP824 is marked 022, there is also a line above the 2, thinking this is 220? I have not checked CP812 for capacitance but can do.it looks like CP812 is the filter cap for the PFC IC pin 8.
I also wonder if these Lytics caps are OK: CM809, CM814, and that CP812.
I also cannot clearly see the RP824 value, it has one end connected to the + leg of cap CP812, the + leg of the CP812 should also show <1 Ohm to point B the leg of QM808.
BTW QM808 P/N? Is it NPN?
QM808 is MPS751Y, datasheet says it is PNP
Positive leg of CP812 to point B as marked on the previous picture is .4ohms. From the + of CP812 to leg 8 of the PFC IC is 22.5ohms
JRM803 is straight through, zero resistance.
BTW QM808 P/N? Is it NPN?Last edited by budm; 02-25-2019, 03:35 PM.Leave a comment:
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
by jesteraceHi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
This specification for the Samsung Galaxy Book Ion NP950XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ boardview and NP950XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
This specification for the Samsung Galaxy Book Ion NP930XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ boardview and NP930XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
This specification for the Samsung Galaxy Book Ion NP950XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ boardview and NP950XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 08:40 PM
- Loading...
