Toshiba 49L621U
  • jjanssen7
    replied
    Re: Toshiba 49L621U
    Shopjimmy has them. They are reliable in my experience. $55 a set for a whole new set.
  • jjanssen7
    replied
    Re: Toshiba 49L621U
    We had a stock of cracked screen TV's that we used. None left now, however. All I have is used strips.
  • jm173
    replied
    Re: Toshiba 49L621U
    Originally posted by jjanssen7
    I have stacks of them but I'm across the border and shipping is crazy. I'd suggest ordering from "the orient". they can't be worse then the ones that are in there already.
    Where do you order from? Can you share a reliable source
  • jm173
    replied
    Re: Toshiba 49L621U
    Cool. Finally opened it up.
    3 out of 12 LED strips burnt. I see which individual LEDs are burnt. But am planning to get a whole new set. Hopefully can work for 5 years more.
    Thanks everyone for your help. I learnt a lot during this first repair.
    Will update when I get the new LEDs.
  • jjanssen7
    replied
    Re: Toshiba 49L621U
  • jm173
    replied
    Re: Toshiba 49L621U
    Cool. Any suggestions on where to get the strips. Seems like this is an old model and they are hard to find.
  • jjanssen7
    replied
    Re: Toshiba 49L621U
    It might be handy to have some spare strips on hand, you will likely find they all test OK with a tester. Only ocasionally I'll find one burnt out. In some cases the TV comes back after a couple of months with a second strip failing, even though I leave it on for 48s after the initial repair...
    replied
    Re: Toshiba 49L621U
    Ok then, looks like they're prone to backlight failure, looks like it's time to do the dirty and strip it down.
  • jjanssen7
    replied
    Re: Toshiba 49L621U
    I've repaired more than 15 TVs of this model. they have all come to me with backlight failure. LEDS come on for a flash, 5 seconds or even up to 5 minutes then BL shuts off but image remains on screen.
    LED strips test OK with LED tester, but are failing under normal load. The way to find the one strip that is failing under load is to test each strip one at a time by plugging in a good known strip in the place of the one being tested. Once you find the failed strip, the BL stay on. It only a matter of time until the next strip fails... I suggest starting with a whole new set.
  • jm173
    replied
    Re: Toshiba 49L621U
    Sorry I got busy. But these are the correct images. Thanks @nomoresonys
    I actually bought a used working power supply. But that one also is not working. Will try more things in the evening.
    replied
    Re: Toshiba 49L621U
    Picture there if it's the correct one: https://www.shopjimmy.com/toshiba-pk...d-for-49l621u/
    replied
    Re: Toshiba 49L621U
    It looks like the PWM controlled MOSFET on the Cathode return of the LED strings are not being turned on.
    I need to see straight shots pictures of the whole top and bottom side of the power supply board to verify.
  • jm173
    replied
    Re: Toshiba 49L621U
    The pin 15 DIM value is 3.1 Volts. This is when it’s disconnected from connector.
    As I turn my TV on the voltages go like this.
    pin 1 vled1- = 35 v and steadily drops to 0.5 v. Stays at this
    pin 2 nc
    pin 3 vled2- = 35 v to 0.5 v
    pin 4 nc
    pin 5 vled3- = 35 v to 0.5 v
    pin 6 nc
    pin 7 nc
    pin 8 nc
    pin 9 nc
    pin 10 nc
    pin 11 vled+ = 108 v to 70 v
    pin 12 vled+ = 108 v to 70 v
    pin 13 vled+ = 108 v to 70 v
    I’ll post pics tomorrow.
    replied
    Re: Toshiba 49L621U
    Originally posted by jm173
    Btw i did try disconnecting the PWM pin 15 and no change.
    So what is the Voltage on DIM pin of the power supply with just DIM pin wire not connected but other wires are still in place?
    BTW, please provide straight shots pictures of your whole power supply board top and bottom side.
    And since now we know that the backlghts do flash on for seconds, set meter to 200vdc scale, then keep black meter probe on the chassis, red probe on the pin 1 vled1-, then turn on the TV while keeping and eye on the meter and record what you see, turn the TV off and repeat the same test on vled2-, vled3-.
  • jm173
    replied
    Re: Toshiba 49L621U
    Ya seems to be a match. I just want to make sure the issue is the power supply and not LEDs. It seems to be fine with the voltages. Any other suggestions before I buy the power supply.
    replied
    Re: Toshiba 49L621U
    That may be a match, as always triple check to try to ensure a match if buying:
    https://www.tvpartstoday.com/PK101W1...k101w1230i.htm
  • jm173
    replied
    Re: Toshiba 49L621U
    I do see the backlight on momentarily at the start.
    I wonder why is there over voltage. Maybe some leds are burnt or not working.
    replied
    Re: Toshiba 49L621U
    Nope. Still 69-70 Volts on all three + pins.
    Tried again with turning off and on. Goes up to 130 then drops to 70v.
    That is what to expected, 70V is the feeding Voltage to the boost converter, the boost comes on but detects over Voltage so boost converter goes into shutdown.
    BTW, you are 100 % sure that you do not see the backlights flash on at all when TV is first turned on?
  • jm173
    replied
    Re: Toshiba 49L621U
    replied
    Re: Toshiba 49L621U
    Do the same test on your post #83 but without LED connector in place, the Voltage should jump u higher than 108V on the VLED+ pins.
    09-06-2024, 05:27 AM
    09-06-2024, 05:59 AM
    09-06-2024, 05:33 AM
