Samsung LED TV UE40D6517WK will not turn on
  • henrikek
    • Apr 2018
    • Sweden
    Hello!
    I have a samsung tv modell: UE40D6517WK. The problem is that the TV will not turn on.
    When I connect powercord the red LED light up and I measured 5,3 volt on (B5V) pin 19 connector CNM803 on PSU modell: BN44-00427A. Everything looks good.
    If I disconnect connector cabel betwen mainboad and PSU the backlight light up and everything looks good.
    When i try to turn the TV on the relay click in PSU and the red LED light start to flash normaly 5 times and then get off. No backlight lights up. I measured the folowing on connector CNM803:
    1 - OD_Level - 4,66 volt
    2 - PWM_DIM4 - 0 volt
    3 - OD_ON - 4,58 volt
    4 - PWM_DIM3 - 0 volt
    5 - GND
    6 - PWM_DIM2 - 0 volt
    7 - B13V - 12,79 volt
    8 - PWM_DIM1 - 0 volt
    9 - B13V - 12,79 volt
    10 - B13V - 12,79 volt
    11 - Vamp - 12,79 volt
    12 - BLU_ON - 0,1 volt
    13 - Vamp - 12,79 volt
    14 - GND
    15 - GND
    16 - GND
    17 - B5V - 5,31 volt
    18 - A5V - 5,32 volt
    19 - B5V - 5,31 volt
    20 - PS-ON - 3,33 volt
    After 16 seconds the PS-ON voltage is dropping the relay clicks and repeats every 16 seconds.
    I does not get any voltage on BLU_ON or PWM_DIMx so i think I have some trubel with the mainboard modell: BN94-05105K (BN41-01587E), but I am not sure? If the mainboard is fault do anyone have any tips which commponent on the mainboard that be fault?
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8325
    Re: Samsung LED TV UE40D6517WK will not turn on
    The main board isn't turning the back lights on. Like you figured already out, the back lights did come on when the main board is disconnected from the PSU. That is because the PSU has a pull up resistor.
    If you follow the BLon / PSon back, it is generated at the main IC on the main board. So you'd need a schematic and then probably find 90% of the time out that the main IC doesn't produce BLon.
    • henrikek
      • Apr 2018
      • Sweden
      henrikek
      Thanks for four quick respond. Does anyone have the shematic for BN94-05105K and BN44-00427A? Or the service manual for UE40D6517WK TV?
        09-07-2024, 05:50 AM
        09-06-2024, 11:40 PM
        09-06-2024, 08:40 PM
        Samsung Galaxy Book Flex NP950QCG-X01DE Notebook Specification for Upgrade or Repair
        This specification for the Samsung Galaxy Book Flex NP950QCG-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-X01DE boardview and NP950QCG-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
        09-06-2024, 06:20 PM
