Low vs and no va on samsung pn64e8000
  • Newcastle
    • Dec 2017
    • 4
    Hi everyone. Great site 👍. I recently picked up a samsung pn64e8000. No power when I got it. Changed a fuse, blew a mosfet and then read everything I could find on this site relating to this particular set and a couple similar posts. I've purchased the rebuild kit from an online source and I still have the exact same issues. Low voltage on vs (4.0v +\-) and nothing on va. Green led in the back blinks on for 5 sec off for 2. Only $100 for the tv and $30 in parts. I'd like to get it going. Not ready to give up yet.
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Low vs and no va on samsung pn64e8000
    Fuse is still good after the repair? What happens when you disconnect y main? Do you get VS and VA at the power supply? To be missing VA with a bad y Main sounds odd. Va should still be there at.power supply rails imho.
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      It would seem the PSU is bad.....can you source a replacement from e-bay or any other source?...If yes...replace PSU....No Va is not a good sign and low Vs......transformers??
      • Nick's Tvs
        • Jan 2014
        • 621
        There are a lot of kits out there that have bad parts. Even shopjimmy kits contain bad parts. I would say your best bet would be to find a used part on eBay or to source the parts yourself from mouser, digikey, or other reputable distributors.
        • Newcastle
          • Dec 2017
          • 4
          Thanks I will look into finding another board. Hopefully I can find one at a reasonable price somewhere
          • Newcastle
            • Dec 2017
            • 4
            I was able to get my local electronics shop to order me a board direct from samsung. I should have it by Monday. Fingers crossed this was my only issue. Thanks again everyone for pointing me in the right direction.
              09-07-2024, 05:50 AM
            • jesterace
              Samsung UE46ES8000 Blown fuse but no other signs of short
              by jesterace
              Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
              09-11-2024, 03:14 PM
              09-06-2024, 11:40 PM
              09-06-2024, 08:40 PM
