Samsung ue32j5200ak bn94-08318b
  • longislandtea
    • Sep 2014
    • 41
    • Italia
    Hi there, i need help, thanks in advance for all.
    My tv reboot every 10 seconds after shows the samsung logo any suggestions ?
    Thanks in advance
  • rocketdog
    • Jun 2017
    • England
    Re: Samsung ue32j5200ak bn94-08318b
    when it reboots do you get a flash from the IR receiver led and then the Samsung logo of so most likely is the main pcb, you could try removing one of the two flat cables going from the toon to the panel trying left then right then out put to rule out cell failure but my money would be on the main pcb
      09-07-2024, 05:50 AM
    • Xristakis795
      samsung ue40d503problem reboot logo only when i have input signal from hdmi and tuner
      by Xristakis795
      hi to all
      i have the above model ue40d5003
      the damage was definitely caused in my case by a generator that I installed burned the protection at power supply of tv and created the following problem
      when I have not connected the antenna, any input source lights up normally i can insert on the menu and the tv doesnt reboot
      when I connect,the antenna or hdmi signal however, when it goes to show an image, the image appears momentarily and then restarts appears the logo and the same again.the lights of standby blinking continously
      Can you tell me from your experience...
      02-09-2023, 03:17 PM
      09-06-2024, 11:40 PM
      09-06-2024, 08:40 PM
