Samsung plasma pn60f5500 -- 5 blinks-- bad panel ??
  • anibal2100
    Anibal
    • 31
    Hello guys.
    I need help with this TV (SAMSUNG PLASMA PN60F5500) that was hit by a lightning storm.
    It was dead so I started checking the SMPS which works pefectly (5.2V. 15V,
    VA and VS are ok tested with 220V lamps).
    Next replaced the mainboard with no luck. (have another working plasma with the same mainboard so no need to order one)
    There is no VS or VA when I attach the Y and X boards to the power supply.
    Just got 5 blinks in the LEd of the mainboard .
    Checked both boards Y-main and X-main for shorts or damaged components and found none.
    Disconnected Y-main from the buffers and X-main from the panel and same thing, no VS.
    Even disconnecting both boards (Y-X) from the PS, there is no VS just the 5 blinks in the mainboard LED.
    I know the mainboard is good because it works fine in the other TV.
    Got stuck there. The only thing I can think about is a bad panel... could it get damaged for the storm ? Even the power supply survived so I don't think so...
    Any help will be much appreciated !!
    Thank you in advance !
    Anibal
  • anibal2100
    Anibal
    • 31
    Re: Samsung plasma pn60f5500 -- 5 blinks-- bad panel ??
    Just as a feedback for those having the same problem: yes it was a bad panel.... (R.I.P.)
    • Nairolf
      Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
      by Nairolf
      I have a Samsung DM32D display.
      When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
      Here’s what I have tried so far:
      1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
      2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
      3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
      From these tests, I suspect the problem might be on the mainboard. Could anyone...
      08-24-2025, 03:47 AM
      09-07-2024, 05:50 AM
    • M80
      Samsung PN51E550D1FXZA plasma no power up 2 blinks
      by M80
      Samsung model # PN51E550D1FXZA plasma TV after a lightning hit (LAN cable was connected to TV). Standby LED on ok, but when pressing the power button, getting 2 blinks on the red LED, the screen flashes white for a second, and then cycles through this loop routine.
      ALL voltages Vs, Ve, Vsc, Va check ok at SMPS output pins and at Main Board connector and X/Y drive board test points.
      Noticed the Logic Board LED lights up green for a couple of seconds, hums lightly, then goes off during this cycling.
      I've reseated ALL connectors and none of the boards have any burned traces or...
      08-11-2022, 04:34 PM
    • bohaboha
      ADVICE FOR SAMSUNG MAINBOARD COMPTABILITY
      by bohaboha
      Hello all of you can any one tell if this Samsung Mainboard BN96-50992B 32" UE32T5300CK is compatible SAMSUNG UE32T5300AK ?...
      04-19-2025, 01:47 PM
      09-06-2024, 11:40 PM
