Samsung LCD TV le40b530p7wxxc no image sometimes
  • ERS
    • Sep 2017
    • 7
    • Portugal
    I own a Samsung LCD tv model le40b530p7wxxc and sometimes when I turn it on there is no image, only sound, I turn it off, wait a moment and when I turn it on again everything is OK. It will only happen when I turn it on.
    I manage to check that there is image (with dark room and a flashlight) and the backlight is off.
    I opened the tv, checked all caps from power supply/inverter board and they all look good, took out all boards to do a visual inpection and there is no signs of problems.
    The problem is pretty random and I couldn't find any pattern, when I was ready to make sure that there is image(dark) while no backlight, I had to turn on and off several times until it happened again.
    There is an attached picture of the power supply/inverter.
    Any help will be welcome! Thanks in advance!
    09-07-2024, 05:50 AM
  • shlomim412
    samsung ua55es6800 - no image
    by shlomim412
    hi
    having problem with samsung ua55es6800
    tv had backlight on, sound working - responds to the remote control but no image.
    check tcon board - had 12v in but no other voltages present.
    when disconnected left ribbon cable - got back voltages and half image with lines and distorsion
    when leaving only left side connected - again no voltages and no image.
    put a tape on all (cd?! lines) on the left ribbon cable and got complete but distorted image (horizontal lines).
    kept trying to block less pins on the left ribbon cable...
    05-15-2024, 05:00 AM
    09-06-2024, 11:40 PM
    09-06-2024, 08:40 PM
