Samsung UN22F5000AF##
  • ramondo
    Confused Member
    • Jun 2015
    • 39
    Greetings All.
    Symptoms
    Set uses an external 14v dc power supply and it is working correctly, reads 14.26v. Red led is lit when plugged in and standby voltages are present. All voltages come up when turned on by remote or jog stick (EXCEPT no 13v panel voltage,no audio,no led backlight and set will not turn OFF by remote or jog. I have service manual (sans schematic,of course) I have repaired Vizio (standby light only) with eeprom replacement so I feel this might be in the same category.
    SOOooo! I;m looking for an eeprom bin file for above set with a Winbond 25Q128FVSG chip. Also can anyone definitely tell me if a firmware update will contain the default eeprom information.
    Any info on reading eeprom lines would be of GREAT help
    PHOTO by SHOPJIMMY.
    Thanks to all for being__WAR_KITTENS____!
    09-07-2024, 05:50 AM
  • Jacksoft
    Samsung 225MW EEPROM bootloop
    by Jacksoft
    I got an old Samsung 225MW TV with BN41-00825 motherboard.
    Since the TV has a buzzer when it starts it makes a beep. The main problem is that the TV goes in a sort of bootloop and beeps every 2-3 seconds.
    So I attached the VGA UART cable and read the debug data using a RT809H programmer:
    According to the Service Manual all the voltages looks good, so I made a backup of the internal flash and all the EEPROMs (1 Settings + 3 EDID) and cleaned the EEPROM.
    Now the TV boots but it's stuck on VGA. If I try to change the source it goes to TV, restarts...
    02-14-2025, 04:18 PM
    09-06-2024, 11:40 PM
    09-06-2024, 08:40 PM
