Sanyo dp50747 samsung internals
  • microvibe
    • Mar 2013
    • 275
    • canada
    I have a dp50747 based on samsung boards.
    Turn on screen it lit up no sound or video shuts off after 15-20sec led doesn't come on or flash on psu.
    Disconnect main jumper self test tv comes on get white screen green screen then shuts off. No flashing on psu led.
    Disconnect all from psu jumper pson and vson power supply stays on until i unplug. All voltages are present except a12v/ac-det is 2.62v on connector in picture. All fuses are good. At a loss where to test from here.
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Sanyo dp50747 samsung internals
    Try running the self test.
    https://www.youtube.com/watch?v=IXXSdctd7Y8
    If that doesn't work check the 5 fuses.
    • microvibe
      • Mar 2013
      • 275
      • canada
      Disconnect main ran self test stays on goes thru test no problem.
      Reconnect main test all protection fault according to manual. On ic1630 pin gets 12v in but pin 2 out is 1v. Would just that ic be issue or could something be pulling pin 2 output down. Supposed be 5v out.
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Normally when it passes the self test it indicates a mainboard fault but wait and see what others think.
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          Sorry but IC1630 means nothing to me not having the service manual. However some pictures and device part number may prove helpful.
          • microvibe
            • Mar 2013
            • 275
            • canada
            Ic1630 is part of protection fault according to manual. Here are some pics. 12v in only 1v out. Part number is 1zc41h. Could I just supply pin 2 with 5volt to see if that makes it work then change out ic?
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              As you say the output voltage (pin2) should be 5V with an input voltage (pin1) of 12V and pin4 should measure 1.26V
              Do a diode check on both D1630 & D1631 with your meter set to diode mode.
              What is the resistance between pins 2 and pin 3 on ohms range?
              • microvibe
                • Mar 2013
                • 275
                • canada
                Pin 2 and 3 were short. I did supply pin 2 side of d1630 with 5v and lifted pin 2 leg of ic1630. Tv function 5v stays steady on that diode 5.12v on all inputs. Picture is good no noisey boards. Been running non stop since last nite. Will order that ic and replace.
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  Have you an update?
                  • microvibe
                    • Mar 2013
                    • 275
                    • canada
                    Haven't replaced ic yet but my band-aid solution tv still going strong
                    • RukyCon
                      A Fake Rubycon
                      • Jan 2017
                      • 816
                      I noticed how all of the output capacitors on the PSU look like they are all Samxon GF caps.
                      Samxon's GF line of capacitors is known to be a bad line of caps.
                      I'm just saying because it probably a good idea to swap them out with something else.
                      I'm not a expert, I'm just doing my best.
                      • microvibe
                        • Mar 2013
                        • 275
                        • canada
                        Just an update my parents still using this tv with band aid fix. 6months and at least 4 hrs of tv lol.
                          09-07-2024, 05:50 AM
                        • signal.quest
                          Samsung LN40C630K1F LCD TV No Backlights and Flashlight Test Fail
                          by signal.quest
                          I have been working on a Samsung LN40C630K1F LCD TV. On power up the backlights only briefly light up when first powered on then they go out (2 seconds to black). The flashlight test also fails. The sound works fine. Please see attached pics.
                          I have researched the forums a lot. I have watched the videos of trying to locate the bad CCFL or transformer and bypassing. I can't find any evidence of a bad transformer/CCFL. I verified I get 376V from the big caps to the fuse. I have used a small/cheap oscilloscope and it looks like the MOSFETs on the inverter...
                          09-30-2024, 11:21 PM
                          09-06-2024, 11:40 PM
                          09-06-2024, 08:40 PM
