This Panasonic LED TV TX-42ASE650 tries to turn on with green LED blinking normally. Backlight flashes shortly 3 times and then it goes to standby with red LED blinking every 4 seconds.
Tried to unplug 12 pin connector that goes to LED backlight and it does the same.
PSU is TXN/P1ZGUB. Everything looks pretty. I haven’t found schematics for this model. These are the components I can identify:
Primary
FA5696N IC7201 Fuji Electric PFC regulator
FA5760N IC7301 Fuji Electric Half bridge switching controller
TK6P60W Q7301 Toshiba N Mosfet
TK6P60W Q7302 Tosbiha N Mosfet
Secondary
NR131S IC7503 SanKen Buck regulator
TPC8132 Q7402 Toshiba P Mosfet
TPC8132 Q7403 Toshiba P Mosfet
TPC8132 Q7404 Toshiba P Mosfet
2SB1181 Q7803 Rohm PNP BJT LED strip switcher
2SB1181 Q7804 Rohm PNP BJT LED strip switcher
2SB1181 Q7805 Rohm PNP BJT LED strip switcher
2SB1181 Q7806 Rohm PNP BJT LED strip switcher
2SB1181 Q7809 Rohm PNP BJT LED strip switcher
Cannot identify LED driver IC7800. SMD component markings are often eroded in the wave soldering process. Also, I haven’t identified TO-220F mosfets that are under heatsinks facing the board.
There’re several test points:
SRV-5.3V is actually 5.2V all the time
SRV-16V is about 16V while the TV tries to turn on
SRV-24V is about 24V while the TV tries to turn on
SRV-VLED peaks at 50V while backlight flashes and then drops slowly
Looks like there’re 5 independently driven LED strips. 2SB1181 transistors are related to each strip. I’ve tried to spot differences between each LED strip voltage measuring pins at PSU connector while the short lapse that backlight is on: all five pins have about 25V. When backlight lights, three of them drop to about 14V, one drops to about 6V, and one drops to almost 0V. My DMM is cheap and slow but this behaviour is deterministic between checks.
So, time to open panel to check LEDs, right?
BTW, I cannot identify this panel. Cannot see any sticker. From T-CON I see it’s a LG panel, but nothing else. No sticker under PSU. Perhaps its sticker is under MAIN board, but I don’t plan to remove it just to see that.
I was about to say this, but someone else said it before. I couldn’t agree more.
Primary
Secondary
Originally posted by jabase
View Post
