Faulty Vestel 17PW06-2 power supply (dropping voltages, no picture)
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    Re: Faulty Vestel 17PW06-2 power supply (dropping voltages, no picture)
    Originally posted by dick_barton
    There is only one transistor on the power supply board which controls the Backlight On/Off (Q206).
    I think you have a fault on the backlight board which is heavily loading the 24V supply when switched on and this is dragging down the other voltages.
    Can you run the set without the backlight connected and use two 12V car bulbs in series as a load to test it.
    Edit
    May also be worth checking diodes D201, D206,D207 & D208
    I believe I mentioned somewhere in one of my earlier posts that all of the test so far have been performed "on the bench", with just the power board and nothing else attached to it, so if it's not stable like this, with no load, it's highly unlikely it will do so under load. On that topic, I've been thinking: if 24V are present at the LED output at all times (even when the BL pin is not connected to 5v) and so are 12v and 5v at the main board connector, why do we need that BL signal on the power board ? What exactly is it switching on on the PSU board. I know the BL signal goes through the LED connector to the LED driver board and switches that on, but what does it do to the power board ? I'm starting to think there's a fault somewhere which keeps the board on at all times (namely that Q306). I think the volts should drop when BL is removed (at least the 24v bus, otherwise WHY would it be on at all times) ? So goddamn confusing >_>
    Wattevah...
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      • Romania
      Edit
      Forgot to mention those 3 diodes (yes, 3 on my board - one is not installed) are fine - even desoldered them and checked them. My meter didn't beep to signal a dead-short and also they had the same voltage drop when forward biased and no "leakage" when reversed biased.
      Wattevah...
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        So to recap. With the power supply disconnected from the main board you have 5V, 12V and 24V all stable until you connect BL_On/Off to 5v via a jumper resistor at which point your supplies become unstable?
        • Dannyx
          CertifiedAxhole
          • Aug 2016
          • 3912
          • Romania
          That is correct. Which again brings me back to the question about WHY that BL pin needs to be attached at all - to my mind, it should only go to the LED board straight from the PSU, considering the LED board always has 24v present and only needs the start signal.
          Wattevah...
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            The backlight circuit on the power supply is minimal components as shown in the diagram so I cannot see how it can have any effect on the supplies. The worse case scenario is that the transistor is short circuit.
            • Dannyx
              CertifiedAxhole
              • Aug 2016
              • 3912
              • Romania
              #26
              Ok, I've just discovered I've been a dumbass this entire time: remember the connector PL200 ? Well, looking at the schematic, it's not clear AT ALL how those pins are labeled, so I soldered my jumper wire to pin 5 by mistake, thinking that pin 1 is SW_SWITCH and pin 5 is BL ON, when in fact the first pin is ground and pin 5 is STBY, while pin 7 is the "real" BL pin. Essentially, instead of sending 5v into BL, I was sending it to STBY.....still, that wouldn't explain why the voltages drop when I do so. That BL pin actually has nothing to do with the power board - it just goes straight through it and into the LED board, confirming my earlier doubts about it serving no purpose. What's next now ? Damn, sorry for the confusion
              Wattevah...
              • Capacitorial
                Powersupply has all the voltages - Monitor still no power
                by Capacitorial
                Hello guys,
                I have a Philips 240B7QPJEB. The monitor seems completely dead.
                I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
                On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
                The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
                The weird thing is, that the Power LED is powered over the TCON board.
                On The TCON...
                12-28-2024, 02:12 PM
              • Jaime Morillo
                Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                by Jaime Morillo
                Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                The TV was stuck on the logo and I couldn't access the update menu.
                I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                The image result was good, but the image is inverted.
                The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                08-18-2025, 11:38 AM
              • France_53
                Vestel tv, how to flip the image?
                by France_53
                Hello everyone from Italy, I'm here to ask for help on a Vestel TV, I've had a Vestel TV branded "XD" with a broken screen for years, but now I've found a Telefunken (still Vestel but older) and I've mounted the panel on the "XD" TV, it works, but the screen is upside down, given that Vestel does not allow you to rotate the image from the service menu, does anyone know how to solve the problem? the original panel is marked ves315WNDS-2D-N12 while the main board 17mb110, the panel I mounted instead in the tv (from the telefunken) is a ves315WNDA-02. ... It is not worth repairing...
                05-12-2024, 05:22 AM
              • FlailingEngineer
                Help with Bush Tv (Vestel 17mb95m Mainboard)
                by FlailingEngineer
                Hi, I was recently given a Bush Smart TV by a friend and the main board seems to be hanging on by a thread.
                Before we get to that, my first obstacle was figuring out the model number since the back sticker has gone for a walk. Upon taking off the back case, I noticed the following Vestel parts, 17MB95m mainboard, 17IPS71 (what I'd assume is power supply) and a VES420UNVL-3D-S02 display panel. After doing some research I think the TV I have is a Bush ELED42240FHDCNTD3D, based on the matching image here (https://www.manualslib.com/manual/11...td3d.html#manu...
                05-31-2023, 06:52 AM
              • gjgib
                Help reading schematic voltages input/output
                by gjgib
                Hello, this might be embarassing since I consider it a dumb question but keeps me kinda stuck sometimes in my journey.
                I want to know if there is any post in this forum which explains my questions. A) When, where and how do I know when X voltage line is input or output. Example:
                I'm battling with this IC to understand it's voltages. It's from non-turning-on Lenovo Ideapad 3 15iil05 - NM-D461.
                I see some lines like +5VL / +5VALW / V9B+ / +3VALW being okay and some others like 1.8VALW / +0.6VS / +2.5V_DDR. I just know that some of them are bad or missing,...
                05-06-2024, 08:11 PM
