Samsung LE37C630 need schematics
  • yoritomo
    • Sep 2012
    • 155
    • Belgium
    Hello all
    I have a TV to repair Samsung LE37C630 with a mainboard problem, it is often stopping and restarting by itself when warm, sometime The Led lit, sometime not, I guess about a reset circuit problem but without schematic it is quite difficult task to resolve. It has a reset button on the mainboard , I was searching some problems there but no success.
    The mainboard reference is : bn41-01443A
    I have been searching everywhere on my favourite free schematics websites without luck, Eservice info, electromaniacs, elektrotanya, monitor.net.ru ...
    I could find the service manual, but does not contains any schematics, how comes ...
    Looks like some powers disappears as 1.5 1.8 and 1.2v but i need to verify with a schema.
    Thank you for your help
  • Diah
    • Feb 2013
    • 6599
    Re: Samsung LE37C630 need schematics
    you checked on MB voltage of L202,L203,L204 disappeared after it turn off, did you check L201 remain had 3.3V. and did the PWB remain support the standby or it cut it. try freeze the Power IC regulator near to the above mentioned test points
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      Is this the problem you are describing?
      https://youtu.be/aET6KWVRagQ
      Have you disconnected the power supply from the mainboard and checked that all the voltages are present when you connect Power_ON to standby voltage and that they stay on?
      Perhaps you could supply photo's of your boards which would be helpful.
      • yoritomo
        • Sep 2012
        • 155
        • Belgium
        Thanks Diah, i will check these values to be sure on friday because tomorrow is the national day here in Belgium, The tv set still in my labo.
        As i could see only 3.3V still on always, but i will confirm soon. As well i will check by oscilloscope, drop downs can makes differences.
        Could you find the schematic then ? I wonder where
        dick_barton yes it is exactly the symptom of that tv set. +5 Stand by looks always good. There is a good quality picture of similar board from the net http://www.duycom.com/wp-content/upl...N94-02625K.jpg
        • yoritomo
          • Sep 2012
          • 155
          • Belgium
          [solved] Samsung LE37C630 need schematics
          hello all
          I did not reply since last time because, the tv was in test period, as i can see the problem it is resolved, no more problems until now.
          The reset button on the main board was definitely the cause, i was careful about it because i am aware by experience about the poor quality of Samsung switch buttons which are getting oxydation to fast usually.
          The best way to clean it is to soak in isopropanol, ultrasonic cleaner is a good option too for the lateral function keyboard of Samsung.
            09-07-2024, 05:50 AM
          • Nairolf
            Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
            by Nairolf
            I have a Samsung DM32D display.
            When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
            Here’s what I have tried so far:
            1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
            2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
            3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
            From these tests, I suspect the problem might be on the mainboard. Could anyone...
            08-24-2025, 03:47 AM
          • bohaboha
            ADVICE FOR SAMSUNG MAINBOARD COMPTABILITY
            by bohaboha
            Hello all of you can any one tell if this Samsung Mainboard BN96-50992B 32" UE32T5300CK is compatible SAMSUNG UE32T5300AK ?...
            04-19-2025, 01:47 PM
            09-06-2024, 11:40 PM
