RCA ctc177AG model F26633SF
  • tatineto
    • Jul 2008
    • 3
    I'm not a techinician but I try to do my best in learning how to fix stuff.
    I just want to ask a question
    this tv RCA chassis: ctc177AG model: F26633SF
    when I turn it on looks fine but is les than 5 minutes
    has a 3 inches on the top black and it starting to show 1 inch on the bottom black.
    all ready resolder all the ground change the eprom but still the same tomorrow i'm going to get the 2 caps by the vertical output C4505 and C4506.
    if anybody has any comment on this tv it'll be apreciated
    thanks.
    Ernesto
  • Krankshaft
    • Jan 2007
    • 2328
    Re: RCA ctc177AG model F26633SF
    Replacing the vertical output caps is a good place to start.
    Also check the supply voltage to the vertical IC.
    The vertical deflection shrinks after the set warms up?
    That's a switch.
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      dieing v out chip.
      bad tuner grounds.
      if vertical shrinks and it gets snowy too its just the tuner grounds.
      i use 2% silver solder.you need a good hot iron too.get all the points that go to the shields too.
      wash out the flux.
      put your original eeprom back in to save you the setup work.its not the issue here.
      • tatineto
        • Jul 2008
        • 3
        supply voltage to the vertical IC pin 2 on the TDA8172 is 24V
        just change c4505 but no luck still the same
        the other cap I'm going to have to buy it online.
        don't know other place that sells them other than radio shack
        the solder that i'm using is opne from Radio Shack #64-013
        thanks.
        • tatineto
          • Jul 2008
          • 3
          yes and it looks folded at the bottom
          • Krankshaft
            • Jan 2007
            • 2328
            Read KC's post.
            If its a dying Vertical output IC purchase some freeze spray (they sell it at Ratshack) power up the TV and wait until the vertical deflection shrinks then blast the IC with the spray if it reverts to normal replace the vertical output IC.
              HP ZBook 14 G2 Base Model Notebook 14 Specification for Upgrade or Repair
              This specification for the HP ZBook 14 G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 G2 Base Model boardview and 14 G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
              09-06-2024, 05:27 AM
              HP ProBook 640 G1 Base Model Notebook 600 Specification for Upgrade or Repair
              This specification for the HP ProBook 640 G1 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 640 G1 Base Model boardview and 640 G1 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
              HP EliteBook 840 G2 Base Model Notebook 800 Specification for Upgrade or Repair
              This specification for the HP EliteBook 840 G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G2 Base Model boardview and 840 G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
              HP ZBook 15u G2 Base Model Notebook 15 Specification for Upgrade or Repair
              This specification for the HP ZBook 15u G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15u G2 Base Model boardview and 15u G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
            • edugimeno
              Vaillant 242 Gas Water heater. Shortcut in board anc compatibility with model 282
              by edugimeno
              Hi!!
              Yesterday I was installing a new Wifi thermostat for my domestic gas water heater model Vaillant 242/2-3, and accidentlly one wire from mains touched one wire from the thermostat output contacts. This shut off the heater so I finished installing the thermostat and then went out to check the heater
              I found one fuse blown (T2 250V). Replaced it with another equivalent fuse and it blew right away. I measured L-N in mains input and I sometimes got 4K but sometimes, not sure why, I got 100 Ohm...
              At a certain point, moving stuff around, I put all wires back in place and...
              03-24-2024, 02:31 PM
