Sony KDL-52XBR4 backlight brief flash, no blinks - mostly solved
  • ripperd
    • May 2016
    Sony KDL-52XBR4, manf date July 2007
    Originally this was going to be a help thread, but I found what I needed through searching this forum and was able to mostly fix the TV, so I'm going to pay it back and post a summary so that future people with the same issue can find the solution quicker!
    Symptoms:
    TV powers on with green power light. Right after power up the backlight will flash briefly and then typically stay off. If you leave the set on for a long time, once in a while it would flicker on for 10 minutes and work 100% perfect. There were NO blink code error messages (until I started disconnecting things).
    I tried a different DF4 board, no change. I tried a different left upper and lower inverter board (rev 0.0 vs my rev 0.4), no change. I tried a different right upper and lower inverter board (0.0 and 0.5 compared to my rev 0.4), no change.
    if I unplugged cn6701 then the backlight would stay on for ~1s (looking fairly even) and then the unit shuts down with a 6 flash sequence. So I thought the inverters were probably OK.
    At this point I was thinking it was one of the florescent tubes due to the age of the TV, even though there were no balancer or inverter errors. I had tried searching online on how to figure out which tube is the problematic one but all of my ohm tests and voltage tests did not identified an outlier.
    Resolution:
    I had tried the above in my free time over the course of a couple months. Finally the other day the wife was sick of it in pieces in our basement and I took another hard look at it. I then found someone on badcaps having a similar issue with an entirely different brand of TV because of the DIMMER signal. I don't recall which thread anymore unfortunately. And then I found the service manual here ( dkneyle - https://www.badcaps.net/forum/showthread.php?t=35607 ). From this I was able to monitor INV_ERR, BALANCER_ERR, and DIMMER (among other things). Everything but DIMMER seemed to check out. DIMMER was consistently very low (cant remember exactly, maybe .01VDC) when it should have been 1.4-3.0VDC.
    I pulled the DIMMER pin from the connector at CN6706 on the DF4 board and powered up the tv and BAM, the backlight stayed on and everything looked good and the TV is working great with the exception of backlight brightness adjustment. I'm not sure where in the range it is by default (the pin on the inverter measures about 2VDC but I don't know if that is meaningful since the signal comes from the microcontroller normally) but for a living room TV the brightness seems to be OK.
    Anyone that has any thoughts on troubleshooting the DIMMER being 0VDC fire away. It would be cool if the unit was fully functioning, although I can't complain as it is very usable right now.
  • Carlos#2003%
    Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
    by Carlos#2003%
    Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
    02-15-2024, 07:52 PM
  • dkneyle
    Sony KDL-46HX850 Can't upgrade/update firmware
    by dkneyle
    Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
    Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
    09-25-2024, 10:44 PM
    Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
    This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
    09-06-2024, 05:27 AM
    Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
    This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
    09-06-2024, 05:30 AM
    Sony VAIO Tap 11 Hybrid (2-in-1) Tap 11 Specification for Upgrade or Repair
    This specification for the Sony VAIO Tap 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Tap 11 boardview and Tap 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
