Sony KDS-R70XBR2 - Repaired OB, Looking to Buy
  • SullyE
    • Dec 2015
    • 21
    Hi Guys.
    I have a decent lead on buying a used and repaired Sony KDS-R70XBR2 1080p SXRD RP LCD set, for (hopefully) around $175.00 if the seller agrees (asking $300.00). I talked with him briefly... he said the optical block in the set was replaced back in 2014 and has been fine ever since.
    I searched for info on this set and didn't see anything... and forgive me if I am not in the right forum (I've only been on here a few times), but I'd like to know if this is something I should just 'steer clear' of or if this thing is worth buying and own for say 5 years, as a rec room TV? Any input/comments are truly appreciated.
    We currently have a 55" Grand Wega (which didn't seem to have the optical block issue) down there now... and is working just fine, but the kid in me always looking for bigger (not always better).
    Please post any thoughts on background/reliability of these. Again, the OB has been replaced... according to the seller. Oh, and it's about an hour away from my house... so that factors in to the "is it worth the hassle" question I keep asking myself.
    Thanks much!
    Gregg
    Re: Sony KDS-R70XBR2 - Repaired OB, Looking to Buy
    I regularly see older HD rear projection sets go for less than £50 here, so the asking price seems a little high. There are questions over bulb longevity, as that will need replacement and also, if the block was replaced outright or just refurbished with a new blue panel (the most frequent failure, but not the only failure.)
    The picture quality on rear-projection sets has always left a lot to be desired from my point of view compared to conventional flat panel displays. Also, the 3-LCD models have convergence issues, especially on refurbished optical blocks, as the individual LCDs aren't lined up perfectly, which creates fringing on the image edges...this is more obvious on larger panels and isn't a problem with DLP rear projection. If I were you, I would look for a good used 60-65" plasma TV. It'll cost more, but you might be able to get one for around $300 now, and you'll get a significant improvement in picture quality with such an upgrade.
    • SullyE
      • Dec 2015
      • 21
      Thank you Tom, I appreciate your time and comments.
      The seller offered the TV for $100.00... so I plan to take it, pending a confirmation that the picture is decent on it. If I get a few years out of it in the basement, I'll be ok with that.
      Take care and thanks again.
      Gregg
      • Carlos#2003%
        Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
        by Carlos#2003%
        Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
        02-15-2024, 07:52 PM
      • dkneyle
        Sony KDL-46HX850 Can't upgrade/update firmware
        by dkneyle
        Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
        Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
        09-25-2024, 10:44 PM
        Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
        This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
        09-06-2024, 05:27 AM
        Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
        This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
        09-06-2024, 05:30 AM
        Sony VAIO VPCM12M1E/W Netbook Specification for Upgrade or Repair
        This specification for the Sony VAIO VPCM12M1E/W Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VAIO VPCM12M1E/W boardview and VAIO VPCM12M1E/W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
