Samsung PS51E490B1K No Display
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    The fault was described as a very loud bang and then no picture. Sound still working which has been verified by plugging in a DVD via it's SCART connector.
    A visual inspection of the circuit boards did not immediately show any signs of damage. All low voltage supplies are up and running however VA, VSC, VE are all incorrect. The led on the control board blinks 1sec ON, 3sec OFF continuously.
    With a meter check the following devices are short circuit.
    Q5012, Q5003 (IGBT, FGPF4536)
    D5005 (Diode, SF10A400H)
    I think it's also best to replace Q5007 (IGBT, FGPF4536) as a precaution.
    I believe the gate drivers are FAN73711 devices but without a schematic I'm not certain of the interconnections.
    If anyone has a schematic they could share or failing that could suggest what other components should be replaced, it would be appreciated.
    What other components would you check that could have been responsible for taking VS down.
    Finally, can anyone tell me what the unit marked “Samsung R.5” shown in one of the pictures is?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Samsung PS51E490B1K No Display
    I had the same set, was just the same Igbts and just them after replacing the set works fine
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      Cheers ReeceyBurger123,
      That sounds encouraging.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Hopefully, just check the power devices for S/C almost never do the controllers get damaged. Also consider checking the Xmain and buffer for possible shorts.
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          The final parts arrived today and were fitted after which I checked that there were no shorts between VA, VS, VE and ground. Powered up the set but once again only sound no vision.
          On checking Va and VS, they were low as in my earlier post.
          Next I checked the parts fitted and found that the IGBT Q5007 had gone short circuit. The board marking in front of the IGBT is YPS. All other parts tested OK out of circuit which was the complete reversal of the initial fault where Q5007 checked out OK but was only changed as a precaution.
          Looking around the board I noticed that capacitor C5009 has the front of it blown off. It measures 330pf which may be the correct value since there are several identical looking capacitors marked 331K,1KV in that area. The diode it’s across checks out fine. Whether or not I missed this in the initial check I’m not certain.
          Could anyone confirm that this is a 330pf, IKV ceramic capacitor.
          I’ve checked the power supply disconnected from the X/Y boards.
          Va = 57.8V, VS = 206.5V which I’ve now adjusted to the values given on the panel Va = 58V & VS = 201V.
          Can anyone see why Q5007 would have blown on this occasion or can point me to a schematic for this model.
          Edit
          Q5012 has since been soldered back in after taking the snapshot.
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            Also found Q5037, K10A50D & Q5030 SMK630 both Mosfet short circuited.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Hmm were they shorted before hand mate ? Also that cap value is correct btw. I never had this with mine I also suggest you check the Xmain for S/C again.
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                I have a board out of another Samsung PS51E480 which to the naked eye appears to be identical. The faulty board from the PS51E490B1K is Rev AA6 and from the PS51E480 is Rev AA7.
                C5009 on this board is 331, 1KV
                Would anyone know if the boards are interchangeable.
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  Thanks Reeceyburger123,
                  I suspect that I did not do a thorough enough check initially and now suffering the consequences.
                  I'm very tempted to swap boards but will wait a while to see what others think.
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Hmm it should be interchangeable, maybe give it a try ?
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      Hello ReeceyBurger123,
                      I'll leave it until the morning and then give it a go unless advised otherwise.
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Ok mate
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          The board swap appears to have done the job. So now to leave it run for a few hours before putting the back on.
                          Thanks for your help ReeceyBurger123 and I hope that this thread is now closed.
                            09-07-2024, 05:50 AM
                            09-06-2024, 11:40 PM
                            09-06-2024, 08:40 PM
                            Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                            This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                            09-06-2024, 06:20 PM
