Samsung HP-T5054 ysus and buffers
  • simplytrini
    • Jul 2011
    • 73
    Good morning Guys, hope everyone is having a great weekend. I am wondering if anyone can help me with an issue i am having with the repair of this samsung plasma. The original problem was the same as descibed in other similar post. I checked the ysus found the bank of 88N30w had shorts, 1 Buffer chip had a hole in it and Q5501 shorted. So I ordered a repair kit from shopjimmy and replaced all 8 buffer Ic's, 2-K2837's, 4-RJH3047, 4-88N30W's and 1 B20NK50Z. I put the boards back in, powered the set up and a short time after the problem repeated again now the bank of RJH3047 have a short and another shorted buffer ic. My question is, can a faulty logic control board be responsible for this? Any help would appreciated. Thank you!!!!!
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Samsung HP-T5054 ysus and buffers
    No. What you have experience is another buffer IC going bad and causing the same catastrophic failure that you saw the first time.
    Is there a possibility that you might a bridged to buffer IC pins together? It's very easy to do especially replacing the buffers yourself.. this model is known for catastrophic y sustain failure unfortunately there's no safeguard against a buffer IC going bad and shutting down the board into protection without doing damage
    • simplytrini
      • Jul 2011
      • 73
      I am pretty sure i didn't have any bridged joints i inspected each chip under a microscope before i put them back. Can it be a bad buffer Ic amoung the new ones I got? I have read That it is possible to get fake buffer Ic's. The other thing i should have mention is that when I plug the set in i can hear the startup sound, screen remained dark and within 15sec boards failed.
      • simplytrini
        • Jul 2011
        • 73
        Is there a place that sells reliable 3407F Ic's?
        • simplytrini
          • Jul 2011
          • 73
          or is there a suitable replacement for them?
          • freakaftr8
            • Oct 2012
            • 3743
            Yes unfortunately I have run across bad buffer IC's where they only last a very short period of time so that might be your issue.
            • freakaftr8
              • Oct 2012
              • 3743
              I have not found a suitable replacement myself. I know some of those Fe IC's are replaceable with a Panasonic equivalent but I don't know about this particular model
              • mmartell
                • Oct 2013
                • 3189
                Yes I have received bad FE3407's from China. Four out of ten had some of the outputs shorted to ground. I may have mentioned about it in a previous post, can't remember.
                Can't help with a substitute part, sorry.
                • simplytrini
                  • Jul 2011
                  • 73
                  Thanks!!! your help is very much appreciated. I will post back when I get the Tv working. Thanks again and keep up the great work here.
                    09-07-2024, 05:50 AM
                  • legg
                    LG 42PC3 buffer output doesn't follow YSUS
                    by legg
                    LG42PC3D -UD originally with green lamp but no display or audio.
                    Owner says was working, then went 'pop'.
                    All 5V caps bulging. replaced.
                    All PSU output voltages within spec but -Vy is low on YSUS.
                    One of three parallel fets between SUS_OUT and SUS_DN is zenering,
                    eventually shorts DG. Replaced all 3 - -Vy now OK.
                    Y scan buffer test point does not follow YSUS output below -50V
                    Note: This unit seems to expect YSUS output to park at -Vy in between
                    drive signal pattern periods. A replacement drive signal board confirms this....
                    11-18-2021, 11:49 AM
                    09-06-2024, 11:40 PM
                    09-06-2024, 08:40 PM
