Samsung UE46ES8000 clicking, power cycling, patterns on screen (video within)
    Had this one on and off for a while, thought I had fixed it originally but no go.
    Have since fully diagnosed it and it is the connector as seen in Samsung attachment.
    https://www.badcaps.net/forum/attach...3&d=1421052377
    Thermal camera really helps for the diagnosis process.
    https://www.youtube.com/watch?v=bJdD...ature=youtu.be
    09-07-2024, 05:50 AM
  • high-tech
    Samsung UN55F7050AFXZA ver. TD01 power cycling
    by high-tech
    Hello everybody, I could use some help on this one... It's got me guessing...
    I took pictures of all the boards and the pin out of the connector on the power supply that goes to the main board... I measured all the pins in relation to chassis ground, here are the result.
    (B13v)1. 12.7 volts cycling (Vamp) 2. 12.7 volts cycling
    (B13v)3. 12.7 volts cycling (PWM5) 4. 1.0 volts cycling
    (OD_LE)5. 2.8 volts cycling (PWM4) 6. 0.9 volts cycling
    (OD_ON)7. 2.8 volts cycling (PWM3) 8. 0.9 volts cycling
    9. ground (PWM2) 10. 0.9 volts cycling...
    09-15-2020, 03:39 PM
    09-06-2024, 11:40 PM
    09-06-2024, 08:40 PM
