APEX model LE 1910 (LED TV)
  • mnpdreed
    • Sep 2014
    • 122
    I have an Apex LED TV. Will not turn on...no power light or back light. It does have 12V at F1 and 12V at the Black and Red wire on the blue color board. Any ideas? Thanls
  • mnpdreed
    • Sep 2014
    • 122
    Re: APEX model LE 1910 (LED TV)
    Any suggestions on what to look for
    • fzabkar
      • Mar 2009
      • 772
      What are the voltages at CN7? Is there a 5VSB? 5V?
      What are the voltages at the regulators - UL1 (+3.3V?), UL51, LD41 coil or nearby capacitor, coil or capacitor ED2 near inverter connector?
      • mnpdreed
        • Sep 2014
        • 122
        Is CN7 the white plug if so 3.3 volts
        UL1 3.3v/1.8
        UL51 0v
        ED2 5.1v
        FE1 12v
        EL54 0v
        EM11 5.15v
        EA12 and EA5 12 V
        EA2,3,4,and 6 0v
        • fzabkar
          • Mar 2009
          • 772
          There appear to be two more LDOs at UT1 and UL41. What are the voltages there?
          Can you tell us the markings on UT1, UL41, UD41, UL51, and the 8-pin IC near ED2?
          My first approach is to verify the presence of the onboard supply voltages. So far it appears that you have found the Vcore (1.8V) and Vio (3.3V) supplies for the MSD3391DS SoC. The 5V supply is also present.
          Where does connector CN7 go? I suspect one group of 4 wires goes to the switch PCB.
          • mnpdreed
            • Sep 2014
            • 122
            UT1 1084B. 33A92V
            UL41 1117B ADB72V
            UD41 gg2j
            UL51 117B AD B72V
            8 pin AIC2857F GR8 07728
            CN7 4 wires to switches 4 wires to power light
            • mnpdreed
              • Sep 2014
              • 122
              UL41. 0v
              • mnpdreed
                • Sep 2014
                • 122
                Ut1 0v
                • fzabkar
                  • Mar 2009
                  • 772
                  UT1 is not an LT1084. Look for it near the HDMI section.
                  ISTM that UL1 should have 0V, 3.3V and 5V on its pins, not 1.8V.
                  AISI, the main board should have a 3.3V Standby voltage. This appears to be present at CN7, presumably for the switches and IR sensor.
                  AFAICT. the 1.8V supply is present, but not where you stated that it was. Otherwise there is some weird fault.
                  I believe there should also be a VDDC voltage for the HDMI section, and 2.5V for the SoC.
                  Can you check your measurements and the part markings?
                  FYI, the Sanyo DP32642 TV uses the same SoC. Although it is a different TV, its service manual has troubleshooting information and circuit diagrams that are pertinent to your Apex.
                  Sanyo TV with MSD3391DS SoC and circuit diagrams:
                  ftp://helpedia.com/pub/temp/datashee...32642-04_Z6TJ_[SM].pdf
                  • mnpdreed
                    • Sep 2014
                    • 122
                    UT 1 has 0V
                    • fzabkar
                      • Mar 2009
                      • 772
                      ICs have more than 1 pin. Therefore they have more than 1 voltage.
                      You still haven't told us what UD41 is doing, eg what is the voltage at the pin going to the LD41 coil?
                      You still haven't confirmed where you measured 1.8V.
                      • mnpdreed
                        • Sep 2014
                        • 122
                        I could not find 1.8v so I guess I read it wrong. I will attach a pic with all the readings I have. I couldn't get the Sanyo li k to open. Thanks
                        • mnpdreed
                          • Sep 2014
                          • 122
                          Did those readings help
                          • fzabkar
                            • Mar 2009
                            • 772
                            Thanks. The 1.8V reading was confusing, but you've cleared it up now.
                            AISI, the +5V and +3.3V standby supplies are present, so the TV is in standby mode. When the TV is powered on, the other supplies should come up, namely 1.8V, 2.5V, 1.26V (VDDC), and a second 3.3V supply, if the Sanyo circuit is any guide. The reason that there are no input voltages on many of the regulators is that this input voltage is switched by the POWER_ON logic. ISTM that you need to find where the input voltages to UD41 and UL51 come from, probably from a MOSFET switch. Then you need to confirm whether this switch is being activated by the MSD3391DS SoC.
                            BTW, the URL for the Sanyo service manual was truncated by the forum software. Just drag your mouse over the entire URL, including the "[SM].pdf" that was cut off.
                            Edit: You should measure the voltages again after pressing Power_On.
                            • mnpdreed
                              • Sep 2014
                              • 122
                              Thank you for helping. I will measure the voltage with power on tomorrow and post. Thank you again!!!!
                              • fzabkar
                                • Mar 2009
                                • 772
                                I've cropped the "Standby Micro Block" from the Sanyo manual. ISTM that the SoC may be brain-dead. I say this because it should be driving the standby LED. If this turns out to be the case (ie no response to POWER_ON at the regulators), then I would check the crystal (Y1) and the voltage on the HWReset pin (216).
                                • mnpdreed
                                  • Sep 2014
                                  • 122
                                  Had no response to power on..no lights...all reading where still the same.
                                  • mnpdreed
                                    • Sep 2014
                                    • 122
                                    I will check the crystal (Y1) and the voltage on the HWReset pin (216) and post results tomorrow. Thanks again
                                    • fzabkar
                                      • Mar 2009
                                      • 772
                                      The voltage at the HWReset pin (#216) should be high. However, I suggest you avoid testing the pin itself since this area is very "busy". A slip of your probe might do serious damage. Instead I would find an appropriate test point at one of the nearby components.
                                      Testing the Y1 crystal would require an oscilloscope with a high impedance probe, so I don't know how you would go with that. AFAICT, it's a 24MHz type so it should be cheap and easy to find.
                                      • mnpdreed
                                        • Sep 2014
                                        • 122
                                        I tested before I read the post. Y1 read 1.4 V. Pin 216 was 0 V
                                          HP EliteBook 840 G2 Base Model Notebook 800 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook 840 G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G2 Base Model boardview and 840 G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 05:27 AM
                                          HP ProBook 640 G1 Base Model Notebook 600 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 640 G1 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 640 G1 Base Model boardview and 640 G1 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          HP ZBook 14 G2 Base Model Notebook 14 Specification for Upgrade or Repair
                                          This specification for the HP ZBook 14 G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 G2 Base Model boardview and 14 G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          HP ZBook 15u G2 Base Model Notebook 15 Specification for Upgrade or Repair
                                          This specification for the HP ZBook 15u G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15u G2 Base Model boardview and 15u G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                        • edugimeno
                                          Vaillant 242 Gas Water heater. Shortcut in board anc compatibility with model 282
                                          by edugimeno
                                          Hi!!
                                          Yesterday I was installing a new Wifi thermostat for my domestic gas water heater model Vaillant 242/2-3, and accidentlly one wire from mains touched one wire from the thermostat output contacts. This shut off the heater so I finished installing the thermostat and then went out to check the heater
                                          I found one fuse blown (T2 250V). Replaced it with another equivalent fuse and it blew right away. I measured L-N in mains input and I sometimes got 4K but sometimes, not sure why, I got 100 Ohm...
                                          At a certain point, moving stuff around, I put all wires back in place and...
                                          03-24-2024, 02:31 PM
