Samsung LED UE32ES6100 ( 5 double blinks )
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    First symptoms were that the tv would reboot on its own.
    Now it wont turn on anymore and the led double blinks 5 times.
    If i remove the tcon cable from the mainboard and turn on the tv, the backlight blinks 2 times.
    Caps look fine....
    Service Manual does not say anything about the blinking leds.
    All backlight leds work! Any suggestions?
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Samsung LED UE32ES6100 ( 5 double blinks )
    Unplug the cable from the Power Board going to the Main Board. Plug the set in the ac and see if you are getting 5Vdc StdBy.
    • Moreno83
      • Jun 2014
      • 2008
      • The Netherlands
      Im getting 5v stand-by
      Also reading 12v on connector going to mainboard and getting 45v on backlight connector.
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        I would say you have a Main Board problem. BTW when you disconnected the main Board from the Power Board and plugged in to the AC, did the backlights come on?
        • Moreno83
          • Jun 2014
          • 2008
          • The Netherlands
          Thx for the reply!
          No with the mainboard disconnected it just stays "dead". No backlight.
          Will see if i can get a mainboard somewhere.
          • Moreno83
            • Jun 2014
            • 2008
            • The Netherlands
            anyone else got any other suggestions before i buy a new mainboard?
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              There are some checks you may need to do before buying the Main Board. Like are you getting PS-ON and BL-ON signals from the Main Board.
              • Nairolf
                Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                by Nairolf
                I have a Samsung DM32D display.
                When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                Here’s what I have tried so far:
                1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                From these tests, I suspect the problem might be on the mainboard. Could anyone...
                08-24-2025, 03:47 AM
                09-07-2024, 05:50 AM
              • bohaboha
                ADVICE FOR SAMSUNG MAINBOARD COMPTABILITY
                by bohaboha
                Hello all of you can any one tell if this Samsung Mainboard BN96-50992B 32" UE32T5300CK is compatible SAMSUNG UE32T5300AK ?...
                04-19-2025, 01:47 PM
                09-06-2024, 11:40 PM
