Dim-Bulb tester
  • rtstorm
    • Feb 2012
    • 971
    • Croatia
    Dim-Bulb tester
    i make myself a dim bulb tester (60W lamp) because i am fixing TV power supply that has been blown Mosfet, resistor and rectifier bridge. I replace component and i do not want to damage them again.
    I power it up over tester and lamp light for 1 sec then turn off, my question is it safe to turn on TV?
    ...the quieter you become the more you are able to hear...
    Re: Dim-Bulb tester
    The lamp glowing indicates current is being drawn.
    Once the lamp goes out, very little current is being drawn.
    If there was a short, the lamp would be on continiously. So it should be OK.
    Most power supplies will do one of several things:
    - The lamp may flash or flicker
    - The lamp may glow once then go out once the main capacitor has charged up.
    - The lamp may glow dimly and the TV may operate (usually smaller TVs will run with a 100W bulb, larger ones may not work or may require a much larger bulb, 150-200W or so)
    Now there is one exception, if the TV has a relay on the power board which may turn off, there could be a short beyond this relay. If there is a relay, you want to find some way to keep it on continuously.
    • CoinCoin88
      Garage door RX unit (Cardin S38C) does not short relay to send opening signal
      by CoinCoin88
      I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
      Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
      09-15-2025, 03:36 AM
    • ezenia
      LUMIMAN Smart Bulb IC ID?
      by ezenia
      I have a LUMIMAN Smart Bulb that suddenly stopped lighting one day. The bulb is still detected in the app, but won't light. I've probed around and nothing seems to look off with any of the diodes, caps or resistors. The Bluetooth/Wi-Fi module seems to be working as it's still detected in the app. I even tried deleting and re-pairing the bulb (it didn't light, but I was still able to follow the pairing instructions), it re-paired fine, but still no light.
      In diode mode, the LEDs all light up when probed so I'm guessing this means the LEDs themselves are OK. I was expecting...
      04-28-2025, 05:56 PM
    • CuriousJohn
      Burco boiler power problem
      by CuriousJohn
      Burco BCPLSAFWM5L 5 Litre Wall Mounted Automatic Water Boiler With Filtration UK 240v
      Does anybody have any experience with these Burco units at all there is no record of them on the forum lol and a proper service manual would be nice. I invite you all to pesuade me not to botch repair it with a 5v relay, read on.
      This unit was rescued from a skip 3 years ago, the only fault it had then was no backight display (plus it wanted a new probe set and top seal) but the screen was never an issue you can still see the screen as is and I just use it to get 5 Litres of very hot...
      12-22-2024, 10:25 AM
    • jm1234
      9V relay temperature 40C
      by jm1234
      Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
      I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
      05-09-2024, 03:03 AM
    • edugimeno
      Biomass Boiler not driving cleaner motor relay. ENERTRES BIOMASA BI-650
      by edugimeno
      Hi everyone!
      I have this board that suddenly stopped supplying power to an output that drives an interchanger cleaner motor.
      I checked while the board was in place with all wires attached and there's no AC voltage on the corresponding plug X5
      This X5 is driven by fuse F8 (tested OK) which comes from the second orange relay
      To make sure there are no charcoaled contacts inside the relay, I got a 24VDC power supply and got it ready to manually power up the coil side of these relays.
      I respected the polarity, positive to cathode of protecting diode
      So provided all...
      04-18-2024, 01:15 PM
