Samsung PN42A450P1D Plasma screen doesn't prime
  • Fwrothy
    replied
    Re: Samsung PN42A450P1D Plasma screen doesn't prime
    VSCAN to gnd= -189.7
    VSCH to gnd=-48.3
    VSCAN to VSCH=141.4
  • Fwrothy
    replied
    Ok so totally disregard #19and. Moving on..
    I pulled of the bezel to check the panel for damage; nothing visible.
    The fuse under the heatsink it is near the 3 big capacitors, is that part of the ERC circuit?
    If so the voltage is ok right?
    Another thing, what is the difference between Vsch and Vscan?
  • Fwrothy
    replied
    Ok I found the GREEN FUSES F5002 top right quadrant of Y-main, 15vdc.
    F5007 is in the bottom right quadrant under the heat sink, 92vdc.
    Both measurement use chassis ground.
  • Fwrothy
    replied
    Rl1 is ~26vdc
    Rl2 is ~35vdc
    10x probe is my only probe at this point and I don't have much practical experience.
    replied
    Yes, sometimes there is also one for Va (~60V)
    Do you have a 10X probe for your scope and are you familiar with using one?
  • Fwrothy
    replied
    Originally posted by MagicSmoke
    Yes the green ones are a fusible resistor.
    So I should have 5 & 15vdc at the exposed legs?
  • MagicSmoke
    replied
  • Fwrothy
    replied
    Originally posted by tom66
    Weird... do you have access to an o'scope? Are all fuses, including small 15V or 5V ones ok on the Y-main?
    I do! Picked up a tek2465 last spring but have not used it yet, been looking for an isolation trans...
    Fl1&2 on Y-main, are those fuses?
  • Fwrothy
    replied
    boards:
  • Fwrothy
    replied
    I only found the one fuse on the ymain...
  • MagicSmoke
    replied
    Check all of the LVDS cables to and from logic board and reseat them.
    replied
  • Fwrothy
    replied
    Yup as per# 3&5
    replied
    Is control board light blinking steadily? (About once a second)
  • Fwrothy
    replied
    Tried the self test-nada
  • Fwrothy
    replied
    Originally posted by Alastair E
    Aye--My mistake Thats the diode--sounds like yours is OK.
    Whats the Voltage on that rivet marked Vscan? Should be about -190
    Yup Vscan(Vsc on panel sticker),Ve, Va and Vs are all spot on.
  • Alastair E
    replied
  • Fwrothy
    replied
    Thanks MagicSmoke, steady once a second, ok I'll replace the ef heat sink and try to power it up, just wasn't sure about try to force it on if it doesn't even prime( been reading plasma threads trying to figure out TS procedures)
  • Fwrothy
    replied
    Thanks Alastair E, do you mean 5014?
    If so it checks out at .485 ( fluke83), good no?
  • MagicSmoke
    replied
    You can disconnect LVDS cable from mainboard to logic, look at logic board and find 4 holes 1,2,3,4 jumper 3,4 with alligator clip or the like, then disconnect power cable from main and use a resistor to jumper 5v Stby to PS-on. There might also be a VS-on pin, if so then that will need a jumper also.
    If it's working properly there should be test patterns displayed, If not then better pics of all boards are needed.
    When logic LED flashes, is it once every second or once every 5 or so seconds?
    09-07-2024, 05:50 AM
    09-06-2024, 11:40 PM
    09-06-2024, 08:40 PM
    09-06-2024, 06:20 PM
