Confirming Fault with Samsung PN50C550G1FXZA Plasma
  • dmanthei
    • Feb 2015
    • 17
    Hello folks,
    I picked up a Samsung PN50C550G1FXZA 50" plasma off Craigslist today
    where the listed fault was "no picture, sound still works".
    I took it home and opened it up and couldn't spot any faulty caps
    or other parts that were clearly toast.
    I plugged it in and turned it on,
    only to hear a sparking sound and a wisp of smoke
    coming from an IC on the lower part of the far-left circuit board,
    which has ribbon connectors up and down the length of the screen.
    Looking at the panel itself, I noticed a small point of impact damage
    that seems to have pierced the outer glass.
    Therefore, is it correct to assume that this impact damage
    has likely resulted in the edge controlling board to fail,
    meaning replacing the panel itself is likely the only solution?
    I've repaired numerous LCDs before, but never a plasma,
    so I don't really know how they work, electrically,
    other than huge voltages required to drive them.
    The TV does otherwise "turn on" and make startup sounds and shutoff sounds.
    The seller isn't responding to my messages
    so, if this sounds correct, I will likely have to part this out to recoup my loss.
  • rccrasher65
    • Mar 2014
    • 622
    Re: Confirming Fault with Samsung PN50C550G1FXZA Plasma
    Sounds like a damaged panel, not cost efficient to replace. Part it out.
      Yes, this sounds right. Unlike an LCD, a plasma will generally not produce any light when the screen is damaged. Damage to modern plasma displays often causes the Y-buffer board to fail, as the electrodes in the screen can be easily damaged.
      Lesson learned! -always- check the screen for obvious damage before picking it up... LCD or plasma! You can see every type of damage to a plasma using a torch (LCD is not always visible, just hope backlight comes on.)
      • dmanthei
        • Feb 2015
        • 17
        Thanks for the replies and confirmation.
        Appreciate the extra bit of explanation, tom66.
        Thankfully I didn't spend a lot of money
        or I'd be more than a bit let down.
        • howardc64
          Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
          by howardc64
          • Prior owner tried a replacement main board. No difference.
          • Samsung 2x red blinking standby LED = panel fault
          • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
          • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
          • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
          07-19-2025, 10:54 PM
          09-07-2024, 05:50 AM
          09-06-2024, 11:40 PM
          09-06-2024, 08:40 PM
