Samsung plasma TV not starting PS50B 450B1DXXY
  • nicklass
    • Jan 2015
    Hi
    I was given this faulty 50" plasma tv.
    It has a red standby light. When i press the on button i here a 1 click and the screen flashes white then off and i here the samsung chime then it clicks off.
    I can see a green light flashing on the x driver board.
    I turned the tv off and waited 15 min, then disconnected the y-z sustain and buffer boards and turned it back on to see if the x driver green light stops flashing but it makes no difference.
    So i think the problem is in the power board (BN44-00274B MODEL P08050A).
    I reconnected all the boards and checked some power connections on the board.
    The low voltages to the mainboard seem fine.
    The VS voltage is 0 volts should be 210 volts.
    The VA voltage is 58 volts should be 55 volts.
    The VSC voltage is 0 volts should be 193 volts.
    the VE voltage is 94 volts should be 88 volts.
    Any suggestions to check the powerboard would be great.
  • nicklass
    • Jan 2015
    Re: Samsung plasma TV not starting PS50B 450B1DXXY
    I'm going to trick the power supply to start up fully as i think the mainboard is not sending the write signal.
    All caps are fine and no signs of crapping themselves. All components look fine.
      09-07-2024, 05:50 AM
    • K212
      Samsung QE65Q700TATXXC is not starting
      by K212
      my Samsung QE65Q700TATXXC has stopped working recently. It worked fine during the morning, and when trying to start it later the same day it just refused to start.
      The standby LED is working, but nothing happens when pushing the power button, other then the LED blinking once. No picture, no sound, no chime, no relay click. I tried a cold start, and other recommended fixes from Samsung. Nothing worked. Then i even tried to reflash the firmware, but nothing happened, not even flashing of the standby led etc.
      I contacted Samsung support who said it is most...
      07-31-2025, 12:45 PM
      09-06-2024, 11:40 PM
      09-06-2024, 08:40 PM
