LG 42PX5D-EB buffer temps
  • bbjunkie
    • Dec 2011
    • 301
    A while back I repaired a LG 42PX5D-EB which had a bad y-sus board.
    Recently I have just obtained an IR thermometer which I thought would be an excellent tool to check the buffer board for suspect chips.
    All but one of the chips are running around 25c (21c above ambient in my cold workshop) the other is running around 9c
    Do these chips tend to run quite warm or could this be a sign of a failure which could blow the new (reclaimed) y-sus board?
    Cheers for now
    Jim
  • legg
    LG 42PC3 buffer output doesn't follow YSUS
    by legg
    LG42PC3D -UD originally with green lamp but no display or audio.
    Owner says was working, then went 'pop'.
    All 5V caps bulging. replaced.
    All PSU output voltages within spec but -Vy is low on YSUS.
    One of three parallel fets between SUS_OUT and SUS_DN is zenering,
    eventually shorts DG. Replaced all 3 - -Vy now OK.
    Y scan buffer test point does not follow YSUS output below -50V
    Note: This unit seems to expect YSUS output to park at -Vy in between
    drive signal pattern periods. A replacement drive signal board confirms this....
    11-18-2021, 11:49 AM
  • howardc64
    by howardc64
    07-24-2025, 05:17 PM
  • ugamazing
    Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
    by ugamazing
    I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
    08-31-2022, 07:34 AM
  • howardc64
    by howardc64
    Problem
    08-04-2024, 10:36 PM
  • Prott
    [RoG Ally] Fault in one of the onboard RAM chips. Any way to diagnose which?
    by Prott
    Hello dear badcappers!
    The title pretty much says it all - do you, please, know if there's any way to troubleshoot which of the integrated RAM chips (LPDDR5X in this case) is faulty?
    Backstory:
    After replacing the 4 onboard (soldered) memory chips on a RoG Ally (4x4 GB to 4x8 GB) it got stuck on the RoG logo. I assume one of the chips is either not soldered properly or faulty. However after reflowing and replacing bunch of them I am still stuck at the same place.
    If there is a way to narrow down which memory module is faulty it would make my life much...
    06-03-2024, 12:05 PM
