Samsung LE40M86BDX Clicking
  • quiggy
    • Aug 2014
    • 136
    • United Kingdom
    Re: Samsung LE40M86BDX Clicking
    My Panasonic caps arrived, I'll fit them tomorrow and hope it comes on, if not, any ideas what else it could be? So I can explore other options whilst I have it open.
    • quiggy
      • Aug 2014
      • 136
      • United Kingdom
      The new caps didn't fix the issue, it's still clicking away
      • zomi
        • Nov 2011
        • 512
        Have you tried to see if it powers on by
        keeping the power button pressed down ( the one on the tv)
        seems like it could be faulty mainboard ..
        that too will make it click away ..
        • zomi
          • Nov 2011
          • 512
          sorry forgot to add did you replace the eeprom ?
          if thats bricked will not boot either some times.
          Or you can try to short it and see
          • johnboy1313
            • Nov 2012
            • 1959
            I had a samsung with a bad T-Con produce the same fault. Unplug the LVDS cable and see if it will power on.
            • quiggy
              • Aug 2014
              • 136
              • United Kingdom
              #26
              Yeah changed the eeprom, held the power button in and tried with lvds cable out, still clicking. Quite frustrating
              • quiggy
                • Aug 2014
                • 136
                • United Kingdom
                #27
                So I left it clicking and after 20 mins it came on
                • quiggy
                  • Aug 2014
                  • 136
                  • United Kingdom
                  #28
                  But when it was on dtv was unavailable and the hdmi ports were also unavailable very strange
                    Sounds like the all-too-common BGA failure on these boards (fault is similar to Xbox 360/PS3 lights-of-death, cracked solder under BGA device)
                    • quiggy
                      • Aug 2014
                      • 136
                      • United Kingdom
                      #30
                      So a reball would be the solution? Do they make stencils for them? Or would i be looking at a basic reflow
                        Reball is the only proper permanent solution - I don't know about the stencils myself. Some people have swapped the whole IC.
                        Also on some of these sets with an "FRC" board, there is an issue with a bad cap around the CPU, worth checking, 1uF SMD electrolytic.
                        • zomi
                          • Nov 2011
                          • 512
                          #32
                          Is there a part number for the bga chip / ic ?
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 5095
                            • New Zealand
                            #33
                            As long as you get the right pad pitch\size, I think a generic stencil will work if you can't find a specific one.
                            -David VanHorn
                            • quiggy
                              • Aug 2014
                              • 136
                              • United Kingdom
                              #34
                              I'll look into it a bit more and see where I end up, cheers guys
                              • steviewonder
                                • Dec 2013
                                • 183
                                • england
                                #35
                                there's a troublesome cap under the tin on the signals pcb that causes this problem.
                                off the top of my head,it's c1110,smd, 1000uf 10v...a quick warm up of the tin should bring the set on,if this is the case.you can see the edge of the cap through the holes on the screening can...
                                Steve.
                                • Nebukadnerzar_V
                                  • Oct 2017
                                  • 24
                                  • Deutschland
                                  #36
                                  steviewonder:
                                  I registered, just to thank you!
                                  That was exactly the Problem with my set. Would have never gone that far to desolder that pain-in-the-arse tin shield, to get to the Cap, if you would not have provided this information. Another TV saved from the yunk-yard.
                                  Thanks again!
                                  • marius19897
                                    • May 2021
                                    Originally posted by steviewonder
                                    there's a troublesome cap under the tin on the signals pcb that causes this problem...
                                    I too registered just to thank you.
                                    TLDR: Thanks to your piece of advice my TV was fixed. Another TV saved from the junkyard.
                                    The TV's model is LE40M86BD. Sometimes when I powered it on the display lit up and showed an image only to disappear a few seconds later as the screen turned off. Then the clicking started and continued for 30-60min after which the TV started for good and worked perfectly. During this time, the image on-off behavior repeated occasionally. The first attempt was to replace all the capacitors on the power board but the TV still wasn't fixed. Then I found your post and decided to get all the capacitors under the tin shield replaced as well. Result: Success! The TV is happy again.
                                      09-07-2024, 05:50 AM
                                      09-06-2024, 11:40 PM
                                      09-06-2024, 08:40 PM
                                      09-06-2024, 06:20 PM
