vivo plasma no picture (samsung boards)
  • maxvalutech
    • Dec 2014
    • 804
    • australia
    Hi this 40" plasma picture went straight off while going, sound ok, remote ok. Internal green light was on flashing at regular interval but later now lights then clicks off. Suspected y main so replaced it today no go all still as was. Now suspect tcon or what it is called but appreciate any advices first. Not really value to fix but ......here we can buy same size led set $299 whereas board even direct from china $60/70.
    . And yes Tom its 2009 model and i have 2 of them other one still ok!!
  • maxvalutech
    • Dec 2014
    • 804
    • australia
    Re: vivo plasma no picture (samsung boards)
    Actually 42" (bad typing) and y sus board replaced. Not keen to swap boards out of good one just in case fault affects good componet on that board. Would like some idea of voltage readings to x and y boards as they seem to read ok from power board but not to y buffer when all connected. Tcon under main board difficult to get at while in circuit.
    • maxvalutech
      • Dec 2014
      • 804
      • australia
      Advice is as dead as my picture or have I done something wrong?!!
      • maxvalutech
        • Dec 2014
        • 804
        • australia
        Ok now established required voltages and read spot on until zmain connected when thet drop to next to nothing except for 15v line but with ybuffer disconnected got proper readings from ymain BUT then found these went away after a while. SO looks like power board has dry joint as voltage still high and reading ok at 2 big caps but not at output socket. Was testing volts at heat sink components and qp803 not reading but then my probe slipped and I blew a piece out of it!! My other set has now turned itself off twice but turns on ok again from remote straight away - we have high summer temps here - problem set often in 35-45 centigrade environment . Have ordered a power board from China and this will be my last attempt at getting it going. Other one will probably go bad soon - both 2009 models .
        • maxvalutech
          • Dec 2014
          • 804
          • australia
          Well disappointed as same problem with different power board in that voltages are on the board but don't make it to vs output as they start running down quickly as soon as switched on and that is without any other boards connected.
          • maxvalutech
            • Dec 2014
            • 804
            • australia
            Resurrected this TV with y buffer made one good PSB from the two I had and got the set going. Have only a VCR to attach which goes OK. Problem now is green red horizontal lines running thru picture and a bit of motor boating of sound from time to time. Next step will undo and reset all contacts from buffers and others inc tcon and report back again.
            • tw2005
              • Oct 2011
              • 6458
              sounds like power issues if there's motor boating and the lines maybe from the mainboard as well. generally speaking the Samsungs have an auto-gen feature on logic ctrl board. if you isolated the main and ran that test and the lines went away then that may help fault finding this. AFAIK it'll auto gen different patterns.
              You'll have to dig a bit to check on the procedure as I've never done it. Some board numbers may help track down the info from other models with the same panel.
              Also if you put some pictures up of the lines.
              • maxvalutech
                • Dec 2014
                • 804
                • australia
                Thanks for that info. Found a DVD player to connect and picture sound both ok. Seems i may have had vcr unit too close to tv which has back all uncovered while testing and probably getting hum from vcr motor. Have to take it upstairs for tv reception point , heavy plasma set, and wife and i in late seventies!!!
                • tw2005
                  • Oct 2011
                  • 6458
                  The 2008 Samsungs were very heavy as were most chassis, each year they got lighter
                  • maxvalutech
                    • Dec 2014
                    • 804
                    • australia
                    Has run for many hours now over 2 days without a problem. Time for the back panel to be put back on and cross the fingers!!
                      09-07-2024, 05:50 AM
                    • Ollerenshaw
                      Samsung plasma tv PN51F5300BF - jerky staticky picture on whole screen until warm up
                      by Ollerenshaw
                      About 50% of time, on switching tv on, there is a jerky staticky picture over whole screen. After some seconds (variable, 5 to 20 seconds) picture suddenly becomes normal.
                      Nothing appears abnormal inside.
                      I'm not a service technician. Main questions: Any ideas as to problem? Worth taking to repair technician? My skills would allow replacing a board but nothing more complicated.
                      Photos and video attached.
                      Thanks for any ideas....
                      11-01-2022, 11:55 AM
                    • Yanleb
                      Samsung UN58TU7000F no picture
                      by Yanleb
                      I have a Samsung UN58TU7000FXZC (same as UN58TU7000FXZA, just the Canadian model) with no picture. Backlight is on and sound is coming out just fine. Just no picture.
                      What is frustrating is that there's no voltage test point and no component labelling of any kind.
                      What I have found so far:
                      1. No voltage at pins 91-94 of the 96 pins connector CN1300 (marked 1 on the picture). This TV set has no T-CON board. The 96 pin flex cable goes directly to the right (when facing TV) lower panel board. Itself is linked with another flex to the other side.
                      2. Voltage...
                      01-19-2023, 01:44 AM
                    • Chris555
                      Samsung PN64E550D1F plasma – sound, no picture
                      by Chris555
                      The TV turns on and works normally for a short time but eventually the video shuts off and only the sound is playing. The problem has been getting worse over the past couple of weeks. Initially, unplugging for a while solved the problem and it worked properly for several hours until the next failure. Now it usually fails after a few minutes and unplugging does not always reset it to a good state. Also, it does appear that using the remote for functions like accessing the menu or changing the video input sometimes causes the failure to occur immediately, though changing the volume seems to have...
                      03-24-2022, 05:02 PM
                    • Yanleb
                      Compatibility of Samsung Y Main boards LJ92-01732A no rev vs rev AA2
                      by Yanleb
                      Hi, I did look everywhere to know if Samsung Y Main boards LJ92-01732A without rev marking is compatible with LJ92-01732A rev AA2.
                      If they are not compatible why did Samsung give them the same part number to begin with?
                      08-04-2025, 11:35 PM
