Samsung ue46c6530
    Re: Samsung ue46c6530
    Pin 18 is PSON.
    • sordids999
      • May 2013
      • 2161
      • uk
      removed some labels and found these
        Connect SW_POWER to A5V_PWR to turn the power board on. Since the board has a built in resistor you can use a piece of wire.
        • sordids999
          • May 2013
          • 2161
          • uk
          jumped SW_POWER to A5V_PWR and reading are as follows
          VAMP 0.00 PS 5.3V
          VAMP 0.00 SB 5.3V
          D5.3V 0.00 D5.3V 0.00
          D5.3V 0.00 GND 0.00
          GND 0.00 GND 0.00
          GND 0.00 H-SY 0.00
          12V 0.00 PWM 5V
          12V 0.00 BL 0.00
          12V 0.00 DET 0.00
            Hmm, that does not make much sense, was that using the legend on the power board, or on the main board? as the one on the main board is in reversed order, you should use the power board one.
            • sordids999
              • May 2013
              • 2161
              • uk
              #26
              i jumped as per picture attached
                You should hear a relay click when the board is plugged in. Do you?
                • sordids999
                  • May 2013
                  • 2161
                  • uk
                  #28
                  yes tom
                    Ok, and then try with the jumper removed, no relay click right?
                    • sordids999
                      • May 2013
                      • 2161
                      • uk
                      #30
                      no click with jumper removed
                        Ok, anything on pins 11, 13 or 14? Can you check on the connector on the main board side?
                        • sordids999
                          • May 2013
                          • 2161
                          • uk
                          #32
                          pin 14 is 3.96 volts
                          pin 13 0.00
                          pin 11 is showing as GND on the markings ?
                          • sordids999
                            • May 2013
                            • 2161
                            • uk
                            #33
                            ok found this while searching i had to translate from german to english
                            hello
                            After I be a Board member (Hubert Jung) still faulty power supply
                            Samsung BN44-00357B left to determine the cause, here is my
                            Results.
                            problem:
                            Despite exchange of nearly all electrolytics the power supply does not start forever! : angry:
                            solution:
                            Investigation of Stdby power supply.
                            1.the Vcc (operating voltage) of the ICB801 is not always available.
                            this is obtained from an additional winding of the stby transformers.
                            in the investigation of the components turned out that the diode DB804
                            (UF4007) temporarily interrupted.
                            after the exchange of the same start of the power supply was carried still quite
                            rather sporadically, so keep looking.
                            Was 2.jetzt the operating voltage at which the other stages (PFC, operating power supply) are started not always provided.
                            The Stdby power supply was stable!
                            So DB805 (UF4007) examined, same error as in DB804, internal contact failure.
                            When resolder the components of the Stdby power supply, in the end, I contracted a capacitor (CB803) as refracted out.
                            This result I do not consider representative.
                            For me 3 Defective components in a stage are a little much.
                            This, however, it is 2 diodes of the same type speaks
                            not for their manufacturers.
                            At this stage, there were two additional installed but no defects
                            had (but I had expected).
                            For problems with this power supply, after unsuccessful Elko exchange this troubleshooting process may, however, at least not hurt (two measurements)!
                            The tensions in Stby should amount to about Vcc 12V and 45V M_Vcc approx.
                            • sordids999
                              • May 2013
                              • 2161
                              • uk
                              #34
                              the capacitor is a SMD.
                              sits between the diode under the ic.
                              area circled in the picture.
                                11,13,14 should all be the same, not different.
                                You should use this legend, to avoid confusion:
                                https://www.badcaps.net/forum/attach...5&d=1416653794
                                That issue is worth investigating, it would seem like the main power supply rails do not turn on when you jumper the lead across.
                                • sordids999
                                  • May 2013
                                  • 2161
                                  • uk
                                  #36
                                  yes tom tried that 11,13,14 should be 5.3volts but all three are reading 0.00
                                    Ok, seems like the primary side needs investigating.
                                    Measure the voltage across (black lead on negative, red lead on positive, you can also use 450V capacitor negative lead as ground reference): CP809, CB808 & CM806, where accessible, with the jumper in place and without it in place.
                                    With power off, check DM853~DM857 for short circuits.
                                    • sordids999
                                      • May 2013
                                      • 2161
                                      • uk
                                      #38
                                      ok thanks tom ill check them out
                                      • sordids999
                                        • May 2013
                                        • 2161
                                        • uk
                                        #39
                                        update :
                                        Psu repaired but on turning on the tv im getting this picture that i have uploaded you can see a picture but with lines,i have tested the tcon fuse but im not getting 12v across the fuse so any advice tcon,main board,panel ?
                                        thanks
                                          You should get 12V on both ends of the fuse, and nearly 0V across the fuse (it's essentially a piece of wire in a box, so you don't expect much drop across it!)
                                          Hard to tell. I'd be tempted to say panel, but I always say that. Not typical for panel fault. So there's a change!
                                          Try this:
                                          - On remote: enter service menu using Info Menu Mute Power (must be done from standby)
                                          - Select "SVC" from menu
                                          - Select "Test Patterns"
                                          - Try Genoa-P/Napoli/or others if available, use enter then left/right to choose patterns
                                          Those are from US model, there's a chance your set is different
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ-K01DE boardview and NP930XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
