Samsung LE40R87BDX EEPROM Dump
  • nogger
    • Aug 2010
    • 190
    Hi all
    Got an LE40R87BDX in at the moment from someone who has already had a go at changing the caps to cure the LED flashing not starting up problem. They made a bit of a mess of it so i have cleaned it up & fitted all Panasonic's as usual but the TV still just flashes &wont start up.
    I removed & blanked the EEPROM & refitted but it still flashes. Although i don't think it will help as i have already tried a blank eeprom i was wondering if anyone had a good eeprom dump for this model ? The main board is a BN94-01472M
    Also, i recall reading somewhere that this fault can also be caused by a voltage regulator on the main board,anyone else aware of this and any ideas which one(s) as these boards are full of them
    Thanks in advance
    Graham
    09-07-2024, 05:50 AM
  • Citymin
    by Citymin
    S/N : 5RNK9FFT70...
    08-05-2025, 05:12 AM
  • AlexGsmMaster
    Eizo CS2740 eeprom dump, search.
    by AlexGsmMaster
    Good day to all, I have a big problem. I can't find the eeprom dump for the Eizo CS2740 monitor. The device doesn't turn on, the indicator just lights up. It responded to connecting to the PC once. The update process started with the standard program and then disconnected from the computer. The computer doesn't detect it anymore. If anyone has an eeprom dump, please share.
    07-26-2025, 03:24 PM
  • saud52
    I need eeprom dump for Samsung UE46H7080
    by saud52
    Hello!
    I need Dump for EEPROM IC901: 24C512
    for Samsung led TV model: UE46H7080
    Chassis: BN41-02167A
    01-12-2022, 09:27 AM
    09-06-2024, 11:40 PM
