Toshiba Regza 42ZV650U Bad picture.
  • andrew409
    • Aug 2014
    • 7
    Hi Badcaps forum,
    I have a Toshiba Regza 42ZV650U LCD TV. Manufactured in May 2009 so it's 4.5 years old. My problem started when I saw a black horizontal line across the top eighth of the screen. It was hard to notice unless you had an image that had a light background. I turned off the TV and unplugged the unit. I replugged it and the line as gone! But the next day, watching TV, the
    black line came back and it got worse! Much worse! The screen below the line became black.
    Attached are the pics.
    Anything below the line is dark and then becomes white. (I assume it's the backlight) Anything above the line is either dark (hdmi input) or white static (cable/ant input). The osd or menu can work in area above the line.
    My question is what is the problem and can I fix it?
    Since can see the osd a little bit might be main board but seeing the line it could be a problem with TCON. Any thoughts on the cause of the problem?
    Regards,
    Andrew
    Re: Toshiba Regza 42ZV650U Bad picture.
    My guess is the LCD panel is bad. Unfortunately this will not be fixable without replacing the screen which is too expensive to do in most cases.
    • andrew409
      • Aug 2014
      • 7
      Hey tom66,
      Thanks for replying.
      Do you think there could be another source for this problem like mainboard or the TCON?
      When I first started to get problems, it was just 1 black line across the screen (1 pixel thick). When you have that, does that suggest main board?
      Regards,
      Andrew
      • johnboy1313
        • Nov 2012
        • 1959
        As Tom said, even the one pixel line would suggest panel failure. Unfortunately, I have to agree with Tom's diagnosis.
        • jord4231
          Toshiba 37AV500A Regza TV good power supply no sound no picture
          by jord4231
          Hi Everyone,
          I'm working on a Toshiba 37AV500A Regza TV.
          The issue:
          TV was working picture and sound went out. Green stand by light stayed on, It will respond to the power button being pressed (goes in and out of standby)
          The TV will very intermittently work for around 40 mins then stop. This doesn't seem to matter if its hot/cold unplugged for a while etc.
          I checked the PSU voltages and everything looked good.
          No bulging caps or signs of heat.
          24v aud = 24.41v
          12v = 11.98v
          5v = 5.062
          p_o/f = Goes high...
          03-29-2022, 09:21 PM
          09-06-2024, 05:27 AM
          09-06-2024, 05:59 AM
