Help identify boards in Samsung plasma
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: Help identify boards in Samsung plasma
    Thing is--even if you did that the PSU would still shut down because the control-board cannot 'see' the correct waveform from that board.
    The fact that the supply rises then falls on turn-on suggests there's no dead-shorts on either board.
    More likely there's a fet etc thats gone open or an on-board derived supply (Y-SUS) is absent....
    TELEFIX
    • jaxmc1023
      • Jul 2014
      • 32
      "control board" meaning Logic board or the main board with inputs?
        Logic board.
        • jaxmc1023
          • Jul 2014
          • 32
          I'm pretty confused now.. Everything I'm reading is telling me that Part# BN96-22107A is referred to as a "X/Y Main Board" or "X/Y Sustain"..
          The power connection to the Sustain board has 13 pins -- Pins 5 thru 10 are all marked "X-Out"
            I can understand your confusion. I think the X/Y main has some functionality of the X-main integrated on it. The X-buffer has what little remains on it. It is an odd design, though. I've never seen it done before.
            • jaxmc1023
              • Jul 2014
              • 32
              What would be your next move? I can't find any shorts on the Y-Buffer (the old one or the new one).. Stand-by and PS_On voltages are correct. VS and VA voltages are correct for a brief moment, but drop out as soon as screen flickers white noise for a split second.
              If I put the old Y-Sustain board back in, would there be any reason that it would damage the new Y-Buffer? or is it always the other way around -- Bad buffer blows Y-Sustain.
              • jaxmc1023
                • Jul 2014
                • 32
                I put the old X/Y Main board back in with the replacement Y-Buffer. Unit turns on, startup jingle, NO PICTURE CHANGE, and voltage drops out
                Took the old back out.. put in the replacement X/Y Main. Unit turns on, startup jingle, brief split-second flash of white noise, and then voltage drops out
                Is this useful info?
                • jaxmc1023
                  • Jul 2014
                  • 32
                  Vs on power supply is 209v (right on the money)
                  Va is only 50v - supposed to be 58v
                  Vsc on X/Y Main is -184v which is perfect, and it actually holds for a few seconds before shutting down
                  According to the fast track, the VA travels through the x-buffer, then through the logic buffer on the bottom of the panel, before reaching the logic board
                  I don't think the y-main is at fault because it generates the correct Vsc before shutting down.
                  Can a Va that's too low signal the logic board to shut off the power supply?
                  • Alastair E
                    Chief Womble
                    • Mar 2013
                    • 1963
                    • U.K.
                    #29
                    The VSc inverter on the Y-SUS in your case, seems OK--However, the Y-SUS board has a LOT more stuff than the VSc inverter on there....
                    A Low Va could I guess signal a shut-down, although how low this threshold is--Ive no idea....
                    Excessive Va will also shut the set down, as excessive Va can destroy the COF chips on the panel tabs....
                    Think at this stage, I would set the PSU to run on its own by grounding VS-ON by 1K and applying 5V via 1K to PS-ON.
                    --Then check the Va and Vs, set accurately and try again.
                    TELEFIX
                    • jaxmc1023
                      • Jul 2014
                      • 32
                      There is a VE voltage listed on the panel sticker, but I can't seem to figure out which Test Point I should test at
                      The only one that looks similar to the VSC test point is marked "VE JP"
                      • Alastair E
                        Chief Womble
                        • Mar 2013
                        • 1963
                        • U.K.
                        #31
                        Aye--Thats prolly it.....
                        TELEFIX
                        • jaxmc1023
                          • Jul 2014
                          • 32
                          Do you think it matters which of those two wires at "VE JP" i test across?
                          • Alastair E
                            Chief Womble
                            • Mar 2013
                            • 1963
                            • U.K.
                            #33
                            I'd check on one nearest arrow....
                            TELEFIX
                            • jaxmc1023
                              • Jul 2014
                              • 32
                              OK. I won't be able to mess with it until I get back home.
                              Assuming the VE does the same as the Vsc (rises to normal level before falling off to 0), is there any danger in trying to increase the Va up to its expected level of 58v?
                              I turned the pot at Va last night about 1/8 of a turn, and that increased it maybe 1v. Was afraid to go much further than that
                                I had an LG plasma PSU that would shut down with a Va of less than 57V; sticker was 60V.
                                • jaxmc1023
                                  • Jul 2014
                                  • 32
                                  You think it's risky to turn that pot enough to go up 8 volts? IF that were the root cause, that would pretty much point to a faulty power supply, wouldn't it?
                                    I'd try increasing Va to the sticker rating but nothing more; the risk is with high Va, the plasma panel can be irreparably damaged.
                                    • jaxmc1023
                                      • Jul 2014
                                      • 32
                                      I turned the Va adjustment Pot as far as it would go, which was only about a half turn. The Va barely reached 51v.
                                      I found the Ve test point, and it reads 102v -- sticker says it should be 91v
                                      Tried adjusting Pots for Ve and Va, but can't turn either of them enough to move them more than 1-2 volts..
                                      • jaxmc1023
                                        • Jul 2014
                                        • 32
                                        I've got another power supply coming in.. Was supposed to be delivered today. Looks like it's going to be late, of course.
                                        I'm out of ideas otherwise. I can't find any shorts on X/Y Main, Y-Buffer, or anywhere else. All voltages do exactly what they're supposed to do, except Va is short by 10volts. Then they all just drop out
                                        • jaxmc1023
                                          • Jul 2014
                                          • 32
                                          Replaced power supply -- all voltages exactly the same. Va still showing 50v when panel is calling for 58v.
                                          I've checked all over the X/Y Main and Y-Buffer, and can't find a short anywhere.
                                          The only other thing that I'm noticing that seems strange, is the voltages for the IR sensor/switch are a little off -- at least according to the fasttrack. Standby voltage is correct at 3.3v, but the guide says all other voltages should be 3.3v also. None of the other voltages - key 1 or key 2 -- is higher than 2.0v.
                                          Was finally able to get a picture of what the screen does when i turn it on -- flashes this for less than a second.
                                            09-07-2024, 05:50 AM
                                          • Yanleb
                                            Compatibility of Samsung Y Main boards LJ92-01732A no rev vs rev AA2
                                            by Yanleb
                                            Hi, I did look everywhere to know if Samsung Y Main boards LJ92-01732A without rev marking is compatible with LJ92-01732A rev AA2.
                                            If they are not compatible why did Samsung give them the same part number to begin with?
                                            08-04-2025, 11:35 PM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
