ADVICE FOR SAMSUNG MAINBOARD COMPTABILITY
  • bohaboha
    • Nov 2012
    • 1017
    • sweden
    Hello all of you can any one tell if this Samsung Mainboard BN96-50992B 32" UE32T5300CK is compatible SAMSUNG UE32T5300AK ?
  • lotas
    • Jan 2016
    • 4809
    • Russia
    CK and AK are different regions, there may also be differences on the motherboard itself (tuner, other panel,....)
    • bohaboha
      • Nov 2012
      • 1017
      • sweden
      thank you so not compatible ? or maybe to adjust in service menu
      • lotas
        • Jan 2016
        • 4809
        • Russia
        I don't know, we need to compare them with each other, how and what kind of LVDS connector is installed on the panel, what kind of tuner is there. And what about the original board, what problems?
        • bohaboha
          • Nov 2012
          • 1017
          • sweden
          Thank you lotas the board here is almost identical to the one i have it is BN96-50992B for TV UE32T5300CK se pic.
          but the problem or the situation is am selling it to someone who have probably the same or equivalent board but for a TV
          SAMSUNG UE32T5300AK i do not now yet how the board looks like i ll ask him to send a pic so we compare and then give him the information
          • bohaboha
            • Nov 2012
            • 1017
            • sweden
            The tables look to be similar so in principle they should fit if not some reprogramming to be performed or perhaps simpler adjustments in the menue service .
            • Diah
              • Feb 2013
              • 6500
              AK CK AU all same, AK sold in UK and other EU lands. so it will work out of the box if its not defect.. meanwhile we do have here threat on AK T5 series
              • bohaboha
                • Nov 2012
                • 1017
                • sweden
                thank you i ll read the thread
                  09-07-2024, 05:50 AM
                • Nairolf
                  Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                  by Nairolf
                  I have a Samsung DM32D display.
                  When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                  Here’s what I have tried so far:
                  1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                  2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                  3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                  From these tests, I suspect the problem might be on the mainboard. Could anyone...
                  08-24-2025, 03:47 AM
                  09-06-2024, 11:40 PM
                  09-06-2024, 08:40 PM
