Samsung UE46D6750WK help please
  • cossiejay
    • Nov 2010
    • 83
    my screen was showing double images so took back of and unclipped one ribbon from tcon board only half screen but perfect picture unclip other ribbon picture went off and now nothing but a blank screen have I blown something or is there some protection built in cant access service menu or normal menu I know on older lcd models you could short the eeprom any help would be great thank you
  • Hamie
    • Apr 2014
    • 1383
    Re: Samsung UE46D6750WK help please
    What voltages do you get on each end of the pico fuse on the t-con?
    • cossiejay
      • Nov 2010
      • 83
      I have 12.6 on each end I have back light but no image at all
      • Hamie
        • Apr 2014
        • 1383
        Did u unhook the tcon with the tv on?
        • Hamie
          • Apr 2014
          • 1383
          You should have test points on the board for.
          Vone
          Voffe
          AVDD
          What are those voltages?
          • cossiejay
            • Nov 2010
            • 83
            yes I forgot tto unplug it and pulled both ribbons fron the board with it powered up
            I have 0 one all points
            • Hamie
              • Apr 2014
              • 1383
              Yeah that t-con is dead.
              Fingers crossed you haven't damaged the panel.
                09-07-2024, 05:50 AM
              • Robby-Gr
                TV Samsung UE55HU8500L (2014) – service menu + firmware reflashing advice needed
                by Robby-Gr
                I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
                However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
                The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
                Additional issues:...
                09-27-2025, 12:02 AM
                LCD LED TV Service Menu Codes
                ALL LCD LED TV SERVICE MENU CODES
                Service Menu Code with Board Name
                China Universal Board / Jumper Board Service Menu Code
                Changhong Ruba Service Menu Code
                Ecostar LED TV Service Menu Code
                Orient LED TV Service Menu Code
                Haier LED TV Service Menu Code
                TCL LED TV Service Menu Code
                Samsung LED TV Service Menu Code
                LG LED TV Service Menu Code
                Videocon LED TV Service Menu Code
                Supra LED TV Service Menu Code
                Toshiba LED TV Service Menu Code
                Symphony LED TV Service Menu Code
                Veste/ LED TV Service Menu Code...
                10-31-2024, 03:58 AM
                09-06-2024, 11:40 PM
