Samsung plasma pn50B550t2f wont turn on
  • Ryckmav
    • May 2014
    • 45
    Re: Samsung plasma pn50B550t2f wont turn on
    I took out those 3 cap (#2 on picture) and test them
    1 read 134uf,other 2 read 131uf,would this be enough to stop all from working?
    or I if I change this main board is best option?
    • martino
      Not so "senior"
      • Aug 2013
      • 997
      • canada
      I somehow missed this thread.....
      Let me put my TV on the bench(exact same TV) and I will take some pic's for points of measurement to get you going on this trouble shooting,I'm no expert like tom66 or budm,tw2005 etc but can help you in comparing voltages etc...
      On mine the Y-sus board is defective,but we'll get to that later...
      Meanwhile,can you take a pic of that mark on the back cover,and also a pic of that part of the y-board that matches up to the spot on the back cover??
      Proud owner of dozens of broken TV's and many,many,many boards.
      Our website and passion:http://hollenhundshepherds.com/
      • martino
        Not so "senior"
        • Aug 2013
        • 997
        • canada
        OK,see picture....I marked 2 components...
        Component 1:
        With TV plugged in,meter on 200volt AC,what voltage do you get between the 2 legs of vx803s(marked as #1),careful when measuring,don't slip or you will have fireworks,don't touch or you will have hair like boy george...
        You should see about 120 volt AC .....
        If you do keep reading.....
        Component 2:
        UNPLUG TV and let sit for 10 for a bit...
        Put your meter on the OHM scale,measure between legs of NT801S(marked as #2)
        You should see about 20 OHM....
        Report findings...
        I put the TV I have on the bench,it's normal to see 0 volts on those 3 caps you marked #2,when TV is in standby..
        • martino
          Not so "senior"
          • Aug 2013
          • 997
          • canada
          Re reading this thread.....see pic....
          meter on 20 volt DC,black probe on chassis of TV,red probe on pin by arrow...What do you get there for voltage?
          **when on my TV,ALL connectors are plugged in and I plug powercord in,the PSU will click twice,pause and click once more....
          When I unplug main and logic board plugs,and plug powercord in,NO click at all....***
          Hence me now asking for this voltage...
          • Ryckmav
            • May 2014
            • 45
            vx803s(marked as #1) read 120 volt
            NT801S(marked as #2) read 25.5 Ohm
            I'll do the other test soon on the 5V pin
            this is the back cover and it's probably nothing,the zoom pic show a shiny spot that could be cause by an arc,but they is nothing in this area but a big plastic mount for optional wall mounting.
            • Ryckmav
              • May 2014
              • 45
              I get 0.44 to 0.79 and never stable,it just keep moving between them 2 value
              • martino
                Not so "senior"
                • Aug 2013
                • 997
                • canada
                #27
                0.44 o 0.79....you measured that with mainboard unplugged??? (just to be sure)
                • Glitcher
                  • Mar 2013
                  • 673
                  • USa
                  #28
                  Okay I skimmed through the thread a little bit.
                  So the TV is just dead, and with no red light in the front correct? This is most probably a problem in the PSU itself. (mainboard is rare to cause this problem but I have seen one)
                  If there is no red light, I'm mostly sure that the PSU is not outputting the standby 5v. Check if you have the Standby 5v. If YES than your problem is the main board. If NO than the problem is in the PSU.
                  • martino
                    Not so "senior"
                    • Aug 2013
                    • 997
                    • canada
                    #29
                    He's getting 0.44 volt on the standby....
                    • martino
                      Not so "senior"
                      • Aug 2013
                      • 997
                      • canada
                      #30
                      see pic...
                      CX820,meter on 20volt DC,what voltage do you measure between the 2 legs?
                      • Ryckmav
                        • May 2014
                        • 45
                        all was plug except for this one I tested (CN801)
                        did the same test with only 120VAC plug and I get 5.23VDC
                        • Ryckmav
                          • May 2014
                          • 45
                          see pic...
                          5.26 Vdc and this cap is loose,not the the soldering but the lead going into
                          the cap
                          all but the 120V ac was unplug.
                          • Ryckmav
                            • May 2014
                            • 45
                            correct;I got no red light,all is dead.
                            I took a chance and order a new (used) board for 56$ all included.
                            • martino
                              Not so "senior"
                              • Aug 2013
                              • 997
                              • canada
                              #34
                              With only ac plugged in you DO get 5.26 volt on the standby pin...
                              With only CN801 unplugged,you get 0.43 volt on the standby pin...
                              That would mean that CN802 is dragging down the 5volt line...Can you test and confirm that?
                              • martino
                                Not so "senior"
                                • Aug 2013
                                • 997
                                • canada
                                #35
                                • Ryckmav
                                  • May 2014
                                  • 45
                                  this is weird,hold on, doing some test because I dont get same reading again
                                  • Ryckmav
                                    • May 2014
                                    • 45
                                    I dont get this no more since I wiggle CX820,the test I did was the standby pin was done before I wiggle CX820
                                    so this would mean CX820 also lost is 5Vdc now, let me check
                                    test done and CX820 still have 5VDC and this Cap is loose as hell so I tried to wiggle again while testing
                                    the standby pin = 0.43 VDC , and did this with 2 different multimeter to make sure,this cap should not be so loose
                                    and as soon I touch it; I got different result.
                                    • martino
                                      Not so "senior"
                                      • Aug 2013
                                      • 997
                                      • canada
                                      #38
                                      If CX820 has a loose leg like you indicated,you might wanna solder it of the board and see if it's shorting out at that loose leg? It's the filter cap,right after the 5 volt(ac) get's rectified,before it get's regulated in IC QB810. It would also drag down the 5.3 volt DC for the logicboard voltage...
                                      • Ryckmav
                                        • May 2014
                                        • 45
                                        the solder is good martino; it's inside the caps that is very loose
                                        • martino
                                          Not so "senior"
                                          • Aug 2013
                                          • 997
                                          • canada
                                          #40
                                          Yes,I understand that
                                          What I'm trying to say is that if that cap is shorted(inside cap) it WILL kill the 5volt standby voltage...
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ-K01DE boardview and NP930XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
