LG 42LC55 random power off fix (AC detect)
  • nw73
    • May 2014
    • 6
    • United Kingdom
    Having benefitted greatly from Tom666's excellent detective work on the LG AC detect problem, I was able to do a fix for this model using that technique, so I thought I'd try and supply some details for anyone else. Full credit to Tom666 really.
    I had the set for a few years (manufactured 2007) before getting plagued with random power offs. Doing some research, most of the hits were related directly to the classic bad caps on powerboard diagnosis.
    I found a kit that was recommended for that, but having swapped the caps, had the same problem, hence more research leading to Tom666's explanation.
    First off - identifying the problem. After the power offs happen, you can see the power off history via the on screen diagnostic menu. To access that, press and hold the menu button on the side of the set, and then press and hold the menu button on the remote control as well. From the resulting menu, you can see the power off history as shown in "power off small.jpg". Entries that show "5V Monitor" are "AC detect" issues - i.e. false detections of a fault on the incoming mains supply. To verify that, you can just pull the power at the mains socket, and then check the menu again. You should see another "5V Monitor" entry, based on a real detection of mains failure (as opposed to the false detections that cause random shutdowns).
    Next up - fixing the problem. Disassembling the set was pretty straigforward (sorry, I didn't do any pics of that) - basically just screws around the sides on the back of the case. Power board is shown in the full-power-board.jpg . Power board model number is EAY38640201 - possibly also EAY39702801 - I guess those are variants. For the classic bad caps, those are ones mostly in the bottom right hand corner of that pic (although they weren't relevant for me).
    There are four couplers that bridge the Primary/Secondary divide. A single one (shown in "1 coupler.jpg") doesn't matter for this fix. Then there is a bank of three (shown in "3 couplers.jpg"). Of those three, PC130 is the only one the bridges in the "correct" direction for the fix. To make the fix, the pins on the right hand side of this photo are the ones that need shorting - i.e. the ones nearest the edge of the board.
    After that, hours of trouble free viewing
    Hope that's useful for someone else.
    Simon
  • ViperRunner
    • May 2013
    • 32
    • Portugal
    Re: LG 42LC55 random power off fix (AC detect)
    Thanks for the information!
    Used your's and Tom66 to fix my 6709900023A with success
    Bet regards
      Nice fix, didn't know it applied to this model
      • netzeus
        • Sep 2017
        • Spain
        Bet regards
        dont understand how did you fix this motherboard!!! maybe is my english is not good, wich of coupler did you short??
          LCD LED TV Service Menu Codes
          ALL LCD LED TV SERVICE MENU CODES
          Service Menu Code with Board Name
          China Universal Board / Jumper Board Service Menu Code
          Changhong Ruba Service Menu Code
          Ecostar LED TV Service Menu Code
          Orient LED TV Service Menu Code
          Haier LED TV Service Menu Code
          TCL LED TV Service Menu Code
          Samsung LED TV Service Menu Code
          LG LED TV Service Menu Code
          Videocon LED TV Service Menu Code
          Supra LED TV Service Menu Code
          Toshiba LED TV Service Menu Code
          Symphony LED TV Service Menu Code
          Veste/ LED TV Service Menu Code...
          10-31-2024, 03:58 AM
        • Robby-Gr
          TV Samsung UE55HU8500L (2014) – service menu + firmware reflashing advice needed
          by Robby-Gr
          I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
          However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
          The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
          Additional issues:...
          09-27-2025, 12:02 AM
        • Retro140
          Unnlock Menu for 2007 DU-27FB32C comerrcial CRT TV
          by Retro140
          So I was referred here when I made this poste over on AVForums: https://www.avsforum.com/threads/loc...lg-tv.3257234/
          To summarize, this is a commercial TV and I can't get a menu of any kind. I know the overlay is working because when I change channel, adjust volume, turn on sleep timer I do see text. But I have not ever seen the user menu nor the installers menu. I've tried a bunch of remotes(more info on the AVF post) and tried every button...
          06-18-2023, 06:13 PM
        • Ierwin
          Philips 58PUS7805 Menu working but no/weird picture from video sources
          by Ierwin
          I got a 58pus7805 that shows some weird behavior.
          The menu and remote work fine and the picture is looking crisp and flawless while navigating the menu.
          However, when a video source is displayed the screen either goes solid green (HDMI), solid black (SAT TV) or shows some fragments on mostly green background (AVI Playback from USB).
          I tried to reinstall the firmware through the menu which was rejected saying it already had the latest version.
          I managed to install the latest official firmware by holding the control button while plugging...
          03-10-2024, 12:50 PM
        • vf fa
          EIZO CX270 - No signal but Backlight and Panel works, logo works, admin menu works. OSD doesn't. What?!
          by vf fa
          Hi, so i guess I´ll have to make a new topic here, as i browsed through hundreds of other threads but couldn't find a solution to my problem yet.
          I got a EIZO CX270 from a friend. He said it doesn't work anymore and wont display any signal or take any OSD inputs. Well, as an aspiring photographer I couldn't say no, could I? Thought it was an easy game, replace a bad cap and have a working monitor. But nooope, it wasn't supposed to be this easy.
          So let me start with the problem description. I'll try my best not to skip anything so this might get rather long.
          01-31-2024, 01:40 PM
